Teraflex control arm relocation bracket work with mopar lift.
Dunerocket
Don
Nevada
21 JLU
I installed a Mopar lift on my 21 JLU, now it wonders all over the place. They say the castor angle is at 5.1. I was wondering if the Teraflex control arm relocation bracket will work with the 2" Mopar lift? The bracket says 2.5 to 4.5 lift, not sure if it would be to much. I will be adding their arms later.
Roky
Roky
Yes they will work, I’m 99.9 percent sure that you got at least 2.5” of lift with the Mopar, probably more than that….
jadmt
jeff
montana
measure here and see where you are at.
Jeep Wrangler JL Teraflex control arm relocation bracket work with mopar lift. IMG_0527-2
jadmt
jeff
montana
also see if you can get your alignment sheet and then post it here. Are you sure your front track bar is properly torqued? Also the lower control arms need to be torqued to 190ft/lbs that is a lot and I have seen those not get properly torqued..
jadmt
jeff
montana
Dunerocket
Don
Nevada
21 JLU
Thanks for replies, I will measure and see where it's at, A reputable Local shop here did the install, so im confident they did it right but, something is off for sure. I forgot to grab the alignment sheet. Pretty sure they go with the info they get with the Mopar kit.
Dunerocket
Don
Nevada
21 JLU
Teraflex replied with their bracket is designed for 3.5 of lift and probably wint work. I took these measurements.
Jeep Wrangler JL Teraflex control arm relocation bracket work with mopar lift. 87122A14-D7F6-46D2-AC5F-20BF06C35413
jadmt
jeff
montana
you will be golden. I have those same measurements(with 2000 miles on the lift) on my AEV 2.5 and run the square washers in the 3.5 position and have zero wander. one finger steering at 85mph. remember if you just installed it you will settle a bit after 1000 miles or so especially if you add weight..
Roky
Roky
According to the diagram above compared to your measurements you got 3.5” of lift….
