2" lift with Rough Country Lower Control Arm Relocation Bracket
b4204t
Kent
Canada
JLU Sahara
Hello,
I have a 2021 Sahara 4 doors with a 2" lift, and I'm interested in the lower control relocation bracket. I came across a kit from Rough Country. I've seen some comments on RC and Amazon suggesting that it's suitable for a 2" lift, even though it's primarily designed for lifts of 3.5" or more. Has anyone used this kit with a 2" lift? If so, how did it work out for you?
Thank you and much appreciated your help!
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
I personally would not do the RC because it appears to be seperate plates.
What lift do you have? The most cost effective quality brackets I've seen are JKS's.
RC: $100
Jeep Wrangler JL 2" lift with Rough Country Lower Control Arm Relocation Bracket 1727286024034-
JKS: $200
Jeep Wrangler JL 2" lift with Rough Country Lower Control Arm Relocation Bracket 1727286052060-d
Poseidon20
DMV Area
www.instagram.com
2001 Jeep Wrangler SE (Sold), 2021 Jeep Wrangler Sport
I was in a similar situation and just decided to go with Adjustable Lower Control Arms. It does the same thing but better. It's barely more expensive but gives you a lot more flexibility.
GATORB8
CLT NC
There are some benefits to the brackets over just adjustable control arms, especially if you aren't concerned about loss of clearance.
Poseidon20
DMV Area
www.instagram.com
Like what? Not trying to sound rude, I'm genuinely curious. I posed basically the same question many times and not once was told to go with the brackets over the LCAs.
b4204t
Kent
Canada
JLU Sahara
RC: $100
JKS: $200
I have a BDS 2" lift kit with JKS sway bar disconnect. The photos from your post, is it the JKS6201? Thank you!
autotragic
the cornbelt
'21 JLR 6MT
Hello,
For less than $100 you can get 2 mopar front lower control arms. They will do the same thing. 68322798AA is the part number.
BetOnBlack
Princeton, TX
2019 Rubicon Unlimited
Supreme Leader of IT
Adjustable control arms only fix pinion angle. They do not fix the actual control arm angl. For the best set up you would want both. Having your control arms as flat as possible helps to reduce the shock/impact forces when you run over something.
I have a rancho lift that netted around 2" of lift. I just used the extended Mopar lower arms for $100 and the rancho control arm brackets and that dialed in perfect.
b4204t
Kent
Canada
JLU Sahara
Oh...this is very interesting, let me check with the local dealer how much they are charging.
b4204t
Kent
Canada
JLU Sahara
Sorry for splitting up my questions, can I use the original hardware for this LCA?
GATORB8
CLT NC
As the ride height increases, the stock control arms are further down in their arc. Near flat (like stock) bumps are near vertical in travel. As the arm angle increases, there is more front to back travel for the same vertical travel. One of the reasons long arms were so popular on TJs, the longer arm is at a flatter angle at ride height.
EDIT: I'll see if this gif works, these are MC's rear brackets but demonstrates the difference pretty well:
Jeep Wrangler JL 2" lift with Rough Country Lower Control Arm Relocation Bracket {filename}
ASSFROW
Gary
Mt. Airy, MD
2024 Rubi X
I'm running them with the stock suspension on my 24 Willys. I ordered them from
AllMoparParts.com , they are a forum sponsor. I believe they were about $75 plus $25 shipping. I ordered XR fender flares at the same time and shipping was still $25, so it was was much cheaper than my local dealer even with shipping.
GATORB8
CLT NC
Yes
EDIT: Did you install the cam bolts for the lower control arms? Do you know what your caster was on the alignment?
