Front Lower Control Arm Brake Line Bracket Question
lsp408
Li
Knoxville TN
2017 JKUS
Any installed set of after market front lower control arms?
What did you do to secure the brake line?
I got a set of JKS arms and the instruction only say to toss the brake line bracket. It never mentioned what to do with the brake line no longer secure by the bracket to control arm
Jkohler
Jeremy
Utah
2018 jl rubicon 2017 Jeep Grand Cherokee 2017 ram 3500
Carefully pry the bracket off the brake line before you take the bracket off the control arm. The line will be fine without the bracket and you'll have more slack in the brake line for suspension travel.
jthoms1
Charlotte
2020 JLUR
Just giving another update/perspective on this. I just installed the Teraflex adjustable LCA’s and as well had to remove the brake line brackets. It can be daunting. I wound up cutting the brackets about an 1” below the brake lines. I then used two channel locks to pry the channel open. Just another idea.
