Teraflex ball joint question
DEdney1775
Daniel
Baton Rouge, LA
2020 2.0 Sport
So I'm replacing mine today. The old ones came out and definitely needed replacing.
I put in the bottom bj & then the top. After I got the top in, I noticed the grease zerk orientation was backwards and it doesn't look like the joint is seated properly..
Can I remove the brand new top joint to reposition the bottom joint?
Jeep Wrangler JL Teraflex ball joint question 20230120_125937
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
is the bottom one flush with the bottom of the knuckle all the way around? thats whats important.
Tech Tim
Summit Sponsor (Level 3)
Tim
Poulsbo, WA
4x4 of all kinds
Yes, you can pull them and reposition them.
Mx5red
Paul
San Diego
2020 JTR, 2020 JLUR
Do you mean you removed the housing? I thought the point of those was that you didn't have to do that, only replace the internals.
XX4XEXX
JD
Ca
2021 Rubicon
Mechanical Engineer
This is typical and they do seat like this but you can set them without the pitch. A few YTs on this.
Remorseless
NC
That's the Dynatrac ball joints. Not aware of the Teraflex joints being rebuildable while in the end forging.
Tech Tim
Tim
Poulsbo, WA
4x4 of all kinds
......and it doesn't look like the joint is seated properly..
When you say it doesn't look like its seated properly, do you mean that groove on top looks to be at an angle?
This right here^^^^
It's that bottom flange that needs to sit flush against the bottom of the C.
DEdney1775
DEdney1775
Daniel
Baton Rouge, LA
2020 2.0 Sport
I meant to get back on here a few days ago & offer thanks to all those that commented & helped. Yes, the bottoms are flush against the knuckles.
Not gonna lie, pulling those old ones out kicked my butt!! Definitely turned out to be an all day job in my garage. But, I saved hundreds doing it myself and learned more about my rig.
When I was putting it all back together, I installed 1" wheel spacers as well. I had to trim the original lug studs down about 1/2". I torqued the nuts down to 110fp and used blue thread locker.
Now, while driving, I'm noticing a little wobble around 30mph... I didn't have any wobble before the ball joint install. Everything was torqued to spec while putting it back together. I may get rid of the spacers & see if it smooths out the ride.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Are those spacers hubcentric, like those from Borah and Synergy? That's an important part when it comes to wheel spacers. Also, torque specs call for 130lb/ft on the lug studs.
DEdney1775
DEdney1775
Daniel
Baton Rouge, LA
2020 2.0 Sport
yes, they're hubcentric. I'll re-torque them tonight when I get home. Thought I read 110 somewhere.. Thanks!
XtremeRetard
Richard
Rocky Mountains
JLURXR
Some wheels only state 100ftlb.. like my beadlocks.. So I have no doubt it varies.
