TazerJL Feature Requests
word302
Oregon
JLU
My search didn't turn up if this has been asked already.
Switching the volume controls from the back of the right side of the steering wheel to the back of the left side would be amazing for us manual drivers.
roll
lance
mississippi
vw tdi
when I make a change, say I put 35 inch tires. If unplug the Tazer do those changes stay or does it always need to be plugged in?
Rudolph Hart
Cheshire UK
2018 JLUR GME Mojito!
Semi retired
The Tazer has vehicle settings (tire size is one of these) which are retained if you remove the Tazer. It also has live settings which require the Tazer to be married to the Jeep.
Thrillhouse28
2019 jlus
I was wondering if it would be possible to add “status triggers” to the Aux Switch programming. The current options are:
  • Type - Momentary vs Latch
  • Power Source - Battery vs Ignition
  • Recall last state
I think some of the status triggers might be:
  • While in reverse
  • When any door is open
  • When tailgate is open
  • When high beams are on
  • When headlights are on
Installer
Jay
Tennessee
Wanting 2020 Wrangler Unlimited Sahara
Sales but wish for retirement
Thtillhouse....
I second your request !
  • Recall last state
  • While in reverse
ASarsano
Tony
Fort Knox, KY
2018 Wrangler JL
SFC - 68W
Enable Autodimming mirror.
I’ve swapped my mirror, Over head harness and wired it to the BCM and ignition just need to enable it in the BCM (options on in my 8.4 uconnect but not the BcM
Moregone
Phoenix, AZ
JLUR
It would be cool if you could disable the alarm button on the remote. I can't help but always hit that for some reason and it drives me nuts fumbling around to get the fob out to turn it off ::honk::honk::
OldGuyNewJeep
Don
CT
You can. It’s an existing feature.
MandKM
2025 JLUR-X, 2008 Horizon Overland AT Trailer. No more CJ5 or ‘19 2-door JL
Manual transmission Jeeps have the ability to restart while in gear, but only within 20 seconds after stalling the engine in 4L. This is helpful during steep ascents or during water crossings when you might not want to depress the clutch, but the time limit and even the 4L requirement are too restrictive.
it would be helpful if the Tazer could allow a restart from stall without a time limit. Lower priority would be to include the ability in 2H and 4H.
One solution may be to have a live command capable of disabling the clutch switch temporarily.
CanAmMick
Mick
Wyoming
2018 Jeep Wrangler Sahara JL, 2017 Honda Pilot Touring
USAF Retired Helicopter mechanic
Is there any way to get the transmission to show what gear it’s in when it’s in Drive, (1 through 8) like it does when it’s in manual mode?
rockadile
PA
2019 Mojito! JLUR
My 2019 does that from the factory. I believe there is a setting in the instrument cluster to enable it.
SwissSteph
Steph
Switzerland
www.swissjeepjl.com
JL Wrangler Rubicon - Hella Yella - 2.2 Diesel
It's just a parameter to change in the car's options from the screen, that's what I did.
CanAmMick
Mick
Wyoming
Thanks! Really appreciate the info.
