Tazer (Programmer) for the JL
Status
Not open for further replies.
islandtees
gary
florida
2025 Final Edition 392
When you make the settings, can you remove both SGW bypass and the Tazer ?
Do you have to keep the SWG bypass in all the time?
FatBoy01
NY
2014 Wrangler Sahara; 2001 Harley FatBoy; 2018 Wrangler Rubicon JL (Ordered)
Retired @ 55
@islandtees Check out the online manual for the programmer. Live features require you to leave in place. Plain features, no you program and then can remove.
islandtees
gary
florida
You install 2 units to make changes, I was asking if you remove both when you change tire size for instance.
FatBoy01
NY
Retired @ 55
Tire size feature is not a Live Feature so you can remove the Tazer JL and the SWG module after you program.
kogar
JD
Cedar Park, TX
JLUR EcoDiesel
Just ordered one. Hopefully they will allow multiple JLs soon. I'm getting a second JL in about 8 months and don't want to shell out for another one of these (of course, by then, there will be more competition :like: )
Chocolate Thunder
Jeremy
Theres no way they’ll ever offer an option for multiple licenses on one device. Otherwise they’d only sell one unit and it would be passed around to everyone who owns a Jeep. They’d have no way to prevent you from letting another person use it even if you promised to only use it on your own two vehicles.
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
Has anyone messed with the sway bar disconnect in 2wd? Does the Tazer need to remain plugged in for that function?
I would love to be able to disconnect the swaybar when driving down crappy at slower speeds with no traffic.
kogar
JD
Cedar Park, TX
JLUR EcoDiesel
Not really, they can set encrypted keys that tie to VINs. It's not hard to do, it just has to be supported in the firmware.
TroyBoy
Troy
Vancouver Island, Canada
I haven’t seen that feature with the new firmware update. I did see swaybar: yes
I assumed that was for people who add an electronic sway bar
FatBoy01
NY
Retired @ 55
snioe:
I think that the "yes" selection is to disable the sway bar system.
TroyBoy
Troy
snioe:
Why would you want to disable it? Just don’t press the sway bar disconnect button.
Or do you mean have it disconnected at all times?
FatBoy01
NY
Retired @ 55
Apparently, you can start the JL/JLU, put it in 4Hi or 2WD and it will stay disconnected regardless of speed.
Amric
Michigan
2003 TJ Rubicon, 2018 JL Rubicon
Does anyone know how low it can set the DPMS sensor warning? Dealership service department told me it can't go below 28psi using their programmer.
Status
