Tazer issue and question.
J_Winslow
Jeremy
Virgina
2022 Rubicon Xtreme Recon
I am trying to fix my speedo for the new tire size, however er no matter what I change it too it does not change tge calibration. I followed tge instructions for the sleep cycles, is there something I am missing?
RugbyRef
Tim
South
2021 Jeep JL 392
You've got to follow the instructions exactly as they are written. I did the same exact thing as you and got very frustrated. Took a break, had a shot of my favorite Tequila, and went back to it. Got it working!
Did you scroll to "Full Reboot" and select it after you made changes? You'll know for sure because you'll see a countdown timer start. Once the countdown is complete, perform two sleep cycles. Do this, in order:
  1. Turn ignition off and close the drivers door (or open then close it).
  2. Wait 60 seconds AFTER the dash goes dark, then turn the ignition on (but do not start the motor).
  3. Do the above step twice.
J_Winslow
J_Winslow
Jeremy
Virgina
Yeah I did that. I am unmarrying it and starting over from scratch now
J_Winslow
J_Winslow
Jeremy
Virgina
Did not work.... still reads 70mph when gps says I'm going 74... I did the full 2 sleep cycles after the full reboot and everything. Everything else works. The TPMS setting save but the speedo does not change
kah.mun.rah
Merenkahre Jr.
Duat
Did you enter the size of the tire as written on the tire or the size of the tire after measuring it?
J_Winslow
J_Winslow
Jeremy
Virgina
I have tried multiple different sizes, the speedo is simply not changing
kah.mun.rah
Merenkahre Jr.
Duat
Is it retaining the new number in the tire size settings after you change it or defaulting back to the original number?
J_Winslow
J_Winslow
Jeremy
Virgina
Retaining the number but not actually changing the speedo. Its 5% off which by the math is what it would be off going from a 35 to a 37.
Punkn89
Alex
Maryland
2019 Wrangler
This vid helped me with mine -
kah.mun.rah
Merenkahre Jr.
Duat
It sounds like the Tazer is doing it's job and the issue is possibly on the Jeep side; however, if you haven't already done it, maybe plug the Tazer back into your computer and update the software and then try again. If it is already up-to-date maybe reach out to Z Automotive. They have been very responsive and helpful when I have reached out to them in the past.
J_Winslow
J_Winslow
Jeremy
Virgina
Does anyone know a firmware that does work for sure with the 22 jlu rubicon xtreme recon?? I have the newest firmware. I wonder if there is an older one someone knows that work with different tire size changes
Suffolklou
Lou
Richland Wa
2020 JLUR
I had the same problem back in 2020 with mine, It would not save the tire size. I had to use a different firmware version, then all was good.
SFDemo
Cbus, Ohio area
2021 Wrangler Sahara EcoDiesel
I would contact Z Automotive directly. When I had a problem with winch mode, I contacted them and they provided great feedback and help.
kingspecialized
Apopka, FL
2021 Sahara Unlimited
I agree with everyone saying contact Z Automotive. I did so when I had and issue. I felt like I was talking to the guy that designed the Tazer.
J_Winslow
J_Winslow
Jeremy
Virgina
Sent them an email per their system as I couldn't find a number
