Joe, how did you resolve this?Iām having issues with my tazer jl, last night I swapped in the led Drls into my Sahara and only the passenger side works. when I have the turn signal on the Amber color comes on and turns off the white DRL, the drivers side has the DRL and Amber always on and it doesnāt matter if I turn the blinker on it stays those 2 colors any help is appreciated thank you
I messed up putting in the bracket that hold the led fender light, one of the screws that hold the bracket was really close to the wiring harness and I caught 2 wires of it when I screwed it in so I guess they were getting power through the screw lolJoe, how did you resolve this?
No need for the Tazer.Is there a way I can disable my fender DRL using the taser mini ?
Unfortunately itās not available thru vehicle settingsNo need for the Tazer.
You can disable it through the vehicle settings.
Are your fender lights Halogen or LED?Unfortunately itās not available thru vehicle settings
I'm not sure how to enable the option within the U-Connect settings, if it's not there already.Mine are originally halogen but Iāve replaced it with LED with its transistor
You put the resister on for the LED turn signals? Which resister did you use and which wire? I upgraded to the LED all around and the hightop fender flares. The lights work great but the turn signal light inside on the dash hyper flashes. So annoying.Mine are originally halogen but Iāve replaced it with LED with its transistor
