Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
ibra_22
Ibrahim
Saudi Arabia
Jeep Wrangler Sahara JL
great job, how did you mount it? and have you experienced any problems?
After seeing the air compressor install behind the drivers side taillight I had to try it with my harbor freight air compressor! Good news, the Pittsburgh air compressor does fit.
Grayhound
Grayhound
Michigan
Jlurd
i don’t completely remember anymore. It was a bolt that I ran through either an existing hole in the base plate or a new hole in the base plate I drilled attached to an oversized washer to catch the body panel behind the taillight.
I have had no issues with this. I still run it this way I use it on occasion and typically can take my 35s from 18psi to 30 on all 4 before it overheats. It also would overheat not installed due to being a low cost harbor freight compressor.
