Air compressor
homebrew
paul
Washington
18 Wrangler JL Rubicon
Looking for a decent air compressor that I don't have to give up a kidney for. I bought a cheap one from home depot that said it would fill larger tires.... it does but it takes for flipp'n ever. Without getting into the ARB budget has anyone found a better alternative?
JohnnyB54
Ronkonkoma, Long Island NY
2018 Sahara
Tritonman
Keith
Upstate NY
2018 Rubicon JLU
ITS Duty Manager
Tritonman
Keith
Upstate NY
2018 Rubicon JLU
ITS Duty Manager
jerseymike
Allentown, NJ
2018 Wrangler JL Unlimited Sport S
I got the puma small compressor with tank, it was a bit over $200 on ebay but works really well, has 100% duty cycle and is built like a tank. only issue is it is big and heavy.
urr2slo
Rick
Phoenix
Denali Duramax, Chevy Camaro, Jeep CJ7, C7 Corvette, MB S63
I got the Bulldog 41000, it's made for filling 37" tires. I have 35's and it airs them from 12 lbs to 35 lbs in less than 2 minutes per tire. I've been extremely happy with it. I bought for temporary use until I installed an onboard air system but it works so well that I've postponed doing it.
Andy2434
Andy
Las Vegas/San Francisco
'19 Billet JLUR, ‘20 Mustang GT/Prem/6MT/PP1
Retired/Leisure
Recently purchased a Viair 400. It will be used as a backup to my powertank.
In testing it out, it works very well.
Hudson
PNW
2020 JLR
Adding to an older thread. I went out with a bunch of JL and JKs on a winter run, aired down to 11 psi. When it came time to air back up, we had 4 different compressors in use. The lowly Superflow MV50, the larger Superflow MV90, a single ARB and a Dual Arb. The MV90 seeem3 the quickest but it still took a long time to air up.
I researched and settled on the Puma PD1006, and will test it out. It has a 1.5 gallon tank and with the hose, wiring and Anderson plugs, I’m into it for about $300. The Puma PD1012 is the same but with a 3 gallon tank. Both are large but not crazy big. They will outperform all of the above and not heat up as much as the Superflow did.
Hudson
PNW
2020 JLR
Update, I tested the Puma and it filled my 35” Ridge Grappler from 15psi to 36 psi in about 2min 30 seconds, not bad
Rodeoflyer
Bert
Conifer, Colorado
I have a VIAIR 450P which is ok.. does the job... but looking at air tank solutions now.
Gorilla57
Chandler AZ
2019 JLUR Mojito
As a point of reference, just in case your budget has risen and you need to fill up tires quickly......my dual ARB via a 4 hose setup will fill my 37” tires from 15psi to 33psi in 6 minutes. It’s quick. The pump cost way too much, but I’m happy with the purchase.
IronScott
NW Arkansas
Jabarsetti
Norman, Okahoma
2020 JLUR
Ret. USAF
Nice, I purchased the Bulldog 4100 it's crazy fast and out performs the SmityBuilt and single ARB too and at $179. only downside is the cheap coil air hose with Japanese Nitto/ type Q plugs. I am spending a few extra $$ to replace the fixtures and use a 50' hose I have on hand then I am going to try and run the cables and Anderson plugs through the cab and into the cargo compartment as more of a permanent power source, I'm not very smart on electrical work so we'll see how it goes.
