Air compressor
Tim_JLU
Tim
2019 JLU Sahara
I am not planning on getting very expensive compressor. I bought one those crap ones on amazon not knowing.
What are you guys using?
I would like to keep it under $200.00
Thanks
SC Notary
Paul
Wellford, South Carolina
2023 Gladiator
Viair 88P7 with the 7 pin round connector for power. They make it also with battery clamps if you don't have a tow package with the 7 pin round connector.
mudfish
Syracuse, NY
'20 JLR 6MT, '04 LJ, '22 Grand Cherokee L
I'd love to hear some reviews of the Milwaukee M18 Air compressors. I keep seeing them pop up and some I already have a few batteries, I was thinking it might be good.
Mifsuud
Phoenix AZ
21 Wrangler Rubicon 4xe
Milwaukee not disclosing the cfm specs is all I need to not see. Physically it seems to be about the same size as most 12v compressors.
I've had a Mean Mother Exitrax 12v for years, never an issue. It stays in the back of the Jeep.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
My Viair has been excellent. I think its 5 yrs old, works like the day I bought it.
stretch-bsn
Northern VA
2018 JLU
I got an “all top” in think it’s called…got it for like $70 on marketplace….works great!
roaniecowpony
Retired Engineer
AndrewS85
Andrew
Maryland
21 Rubicon
Viair 400. Found mine on marketplace for $100.
jojosmith
Virgil
Lake Charles, Louisiana
2023 Gladiator Mojave
vetygud
Michael
Nisswa, MN
2022 Jeep Willys 2 door Sarge
Retired LEO
I use a Milwaukee M18 Air compressor for my JL and Silverado. Works great when temps drop sub-zero and the tires need to be topped off. Usually up to 10 psi. I put a quick clamp air chuck on and it is in a padded Amazon case with extra battery storage. It would take awhile to do four air up tires but it would get the job done. I have multiple M18 tools so I have plenty of batteries. Works great for my needs. I do not air down to low pressures.
Jeep Wrangler JL Air compressor M18
roaniecowpony
Retired Engineer
I've been using a Viair 440P which fits in a plastic "ammo" box from Harbor Fright. My 2 hose system is just made up of Harbor Fright hose and fittings. Works well enough. But I'm going to mount a ARB clone under the seat and run a QD to both sides, then make up a double hose for each side, equating to a 4 hose system. Not sure I'll like all the hoses. I like "easy". If I can take a couple steps out of the process, I'm all for it.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
If you are looking to fill and deflate fast here is what I did. Its volume of air or CFM that's will give you the fast inflate.
I installed an ARB twin put any compressor can benefit from this upgrade.
1. Use only high flow fittings like the JACO Hi-Flo Quick Connect Air Hose Fittings.
2. Use only 3/8 air hose.
3. I drilled and taped my wheels 1/4 pipe and installed Haltec H-47 : Large Bore Tank Valve.
I can now deflate one tire from 28psi to 9psi in about 30 seconds.
I can fill two tires at the same time from 9psi to 28psi in about 2.5 to 3 minutes.
What's nice about this set up I can have the pressure gauge on the normal schrader valves wile deflating or filling with the large bore valve.
https://proquip.solutions/H-47/?srsltid=AfmBOoqyN73GgK0hIUnaddXjPRXITgSsnYadkt___0BAmeMyq6e63S2n
https://www.amazon.com/dp/B093KHZF9D?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_26
https://www.amazon.com/dp/B09GW4J3P3?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_20
Jeep Wrangler JL Air compressor IMG_1985
Jeep Wrangler JL Air compressor IMG_1986
west tex
Skoro
2021 JL 2dr 80th Edition, 2017 Renegade Trailhawk
Retired, as in "Tired again"
My Viair works like a champ.
