synergy springs
wanderer
Ralph
Carlsbad CA
Engineering Geologist
hey, who is running
synergy springs on your
jeep?
Which ones are you running and for how much lift?
And also a general question about spring if I have a 2 1/2 inch lift on there and I wanna swap springs I have a choice of 2 inch or 3 inch. It seems to me I should go with a 3 inch springs am I thinking correctly? However, my lift is a metal game changer lift 2.5 “
And it appears that I got at least 2.5 inches of of additional travel just by looking at how the bump stops sit inside the spring, but the fender height above the tires is more like 8 inches and I did not measure any distances before or after the left? So should I go 3 inch springs or 4 inch springs maybe?
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Why are you changing springs?
RhinoJLU
Ernie
New York
JLU
I have been using the 3 inch springs for 4 years on my 4 door with 37s. Great combo very pleased
Jaym
Salt Lake City
2018 JLU Rubicon
wanderer
wanderer
Ralph
Carlsbad CA
perfect glad to hear cause I’m going that way this week with the metal cloak lift
What ift are you running? And did you re-gear I’m running 456 right now.
F4Flyer
Littleton
2024 Rubicon X
I USED to run Synergy springs on my two past JKs. I ran a few others but Synergy was my favorite...just a bit stiffer than stock (which was wallowy) and a great ride on road and off road. Both my JKs were not too heavy- just sliders, winch, and mid width bumpers that were not super heavy like many.
Jaym
Salt Lake City
2018 JLU Rubicon
Good to hear. I just ordered the 3” synergy coils.
F4Flyer
Littleton
2024 Rubicon X
Good choice. I had the 3" as well. I am tempted to switch on my Rubicon X but I am not sure which one...I suspect the 2" ones will give me the same height as the stock coils. My Rubicon X with 35s seems to be 1" or so lower than my JKUR lifted with 3" Synergy coils and 35s.
Jaym
Salt Lake City
2018 JLU Rubicon
I currently have 1.5” Clayton and I am definitely higher than both the Xtreme Recon jeeps and i think even the Mopar 2”. I hope synergy raises me up a little more. Also, I am very glad synergy coils are softer—much easier to make your ride softer or firmer with shock control and plush coils. Once you go stiff coils you’re stuck with stiff ride, unless you are heavy.
wanderer
wanderer
Ralph
Carlsbad CA
really glad to hear that. i have a metal cloak lift 2.5 inch game changer with the black adjustable resivoir shocks the jeep rides really stiff even on the smallest of irregularities in the pavement,it literally rattles my teeth. metal cloaks springs are 185 lb front and 200 lb rear . That is way too stiff for my jeep . It has the factory winch and steel bumpers. To be candid I am rolling the dice on these springs . going off posted spring rates in this forum.
redsyphon
North Florida
2018 JLU Rubicon
IT Project Manager
I have been running Synergy springs since day one on my 2018
I started with 2in springs and have recently replaced them, after 6ish years, with Synergy 3in springs (ex. https://www.northridge4x4.com/part/...front-coil-springs-jl-2dr-4in-jl-4dr-3in-lift) with leveling pucks in the rear to have a level ride when it's loaded down with gear.
I live the ride and it leaves plenty of room for my 35s. I could easily run 37s as well, but I like a smaller/lower build.
I have always gotten complements on the ride, and I've found no issues with it even after multiple 18+ hrs drives out west (from FL).
I find they give almost the exact amount of lift as advertised and don't settle as much over time as other springs I've had on other vehicles in the past.
Jaym
Salt Lake City
2018 JLU Rubicon
Awesome. Can you share photos of your jeep on the 3” coils and 35s? Would love to see it
F4Flyer
Littleton
2024 Rubicon X
Metalcloak and Clayton have traditionally used stiffer springs, and even AEV does. I avoid those since I build relatively light Jeeps.
