Sun visor warning decal removal mod
STG01
Wisconsin
19 Rubicon
Heat gun or blow dryer to play it safe. Takes a little time to warm it up and go slow. Pull some off, warm again, etc ... all came off one piece. Can see a small shadow, but not too noticeable and that fades over time.
Jeep Wrangler JL Sun visor warning decal removal mod 517284DD-F1F0-4065-AE99-4D0D7B229187
Jeep Wrangler JL Sun visor warning decal removal mod 542B6A5A-2FA7-4FD0-9D92-5FE79822D5AB
Jeep Wrangler JL Sun visor warning decal removal mod C13E34FF-1F78-4B7A-B5D2-679D6052AE45
jmcdtucson
Jerel
Tucson, AZ
2018 JLU Sport S
I used a hair dryer because a heat gun was a bit of overkill.
The method above is key. Heat it up good. Then get a corner started.
Heat 2 or 3 seconds. Then pull gently - maybe only move it 1/8" at a time. Then heat more. Pull another 1/8".
The key is not to break it or you have to start another corner which is a PITA.
Looks great. The rectangle is far more visible in pictures than in real life.
Jeep Wrangler JL Sun visor warning decal removal mod IMG_20190804_172524
WillysMeow
Corruptifornia
Bought my first new Jerp! :)
Bit wrassler
@Goin2drt
As you see, the outline is faint but it is what it is. 8-) The outline is not going away but I can tell you in short order, you will rarely even take notice of that faint outline. I know you can't say the same for that ridiculously gawdy safety decal that was there.
Remember, you can still place a decal over where the decal was and that will cover the faint outline... but then you will be looking at a decal that does not match the color of the visor..
For those that will be removing the safety decals. Do use a very low heat setting on your hair dryer. First heat the whole decal and then quickly go to a side of it and start peeling it off as you continually hit it with the heat. Careful not to over heat / melt the visor's vinyl. Peel , pull slowly and gently so you do not stretch the heat softened visor's, vinyl. You will see the vinyl is soft and giving a tad but it will go back into shape.. Just go easy and expect to be working on each visor for a good half hour +-.
This is what worked for me, maybe 40F and hair dryer did nothing (even on high), heat gun on low and don't get too close, work a corner up and then gently pull towards the other end like opening a zipper. Had to kinda heat a bit more and then pull farther until all the way off. Got some residue, wd-40 and GooGone didn't seem to help, but at least the stupid warning stickers are gone!
The vinyl did bag/stretch a little when heated but let it cool and back to tight and flat.
WillysMeow
Corruptifornia
Bit wrassler
This morning the sticker haze is much less pronounced, guess wiping it down with WD-40 and then GooGone helped, looks 1000 times better, thanks for the help!
Jammer
Ft worth
Bright white JL Rubicon
I bought a decal that is the exact same size in black for both sides that says Rubicon and it fits over perfect
WillysMeow
Corruptifornia
Bit wrassler
Thanks that's one way to fix it, but I wanted them gone as in nothing to see there or peel later. :)
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
I didn't even realize they were there. After reading this I confirmed, they are there and now I want them removed or covered.
YGBSM392
Oklahoma City
2025 Rubicon 392, 2024 2-Door Rubicon X, 2024 Mojave X
I fly da plane...
WillysMeow
Corruptifornia
Bit wrassler
This morning after sitting overnight with GooGone wiped onto them, almost no longer visible.
Jeep Wrangler JL Sun visor warning decal removal mod IMG_7685
Last night right after removal, that's the shrunken leftover from driver's side. Merry Christmas!
Jeep Wrangler JL Sun visor warning decal removal mod IMG_7682
Flip
Johnny
Virginia
I like the Christmas lights, they look good. 👍
