visor sticker removal
Brotman
Chicago
2025 2 door Wrangler
does anyone have a "fool" proof way to remove the visor stickers?
i've seen most of the videos options, rubbing alcohol or heat gun, but they seem kind of hit and miss. i tried a hair dyer and it did nothing, maybe not hot enough.
hate those stickers !
There’sOnlyOne
Greg
NW Georgia
2021 JLUR
if you don't want the hassle of removing them and like the idea of a novelty decal, there are ones out there that you just decal over the existing factory ones. other than a heat gun with caution not sure how else you would be successful on removal.
WillysMeow
Corruptifornia
Bought my first new Jerp! :)
Bit wrassler
The sooner they are removed, the easier because they eventually get baked on.
Hair dryer is not hot enough, need a heat gun but be careful that you don't melt the vinyl. It's also easier to do when the weather is warm out as they don't immediately cool off. Mine were pita even with heatgun and at first came off in little pieces, then once warmed enough peeled off in a large piece or two. After removal, I wiped the areas down with little WD-40 on a cloth, at first could tell where they had been but after couple months that fades away. Good luck.
Brotman
Chicago
hadn't heard of those, thanks. definitely the easiest solution
2nd 392
Ca
I used the pixel decals, they are a little higher gloss than the visors. After a couple weeks deciding I put them on. It’s noticeable, but much better than the warning stickers.
jrgator1
Daytona Beach, Florida
2021 Jeep JL
I hate those ugly stickers. I recently removed mine in an Audi SQ7. They were on alcantara, and the consensus method was to use 91% isopropyl alcohol available at most drug stores, Walmart etc. Not 70%. Lightly soak paper towel with it and place it on visor 10-20 minutes, covered with plastic wrap. Patiently peel it off, and if resistance, re-soak. I'm unsure about doing them on the jeep.
Terrymo
Terry
2023 JLURXR 3.6 ET
TBASCO
Midwest
26 Ford-29 Ford-23 Corvette-24 Camaro-24 Silverado
If you have a friendly sign shop in your area, ones that do lettering on commercial vehicles, they will have a variety of black vinyl, glossy, matt, flat, and probably others. Most will sell you a small amount off a roll or from left overs.
YGBSM392
Kevin
Oklahoma City
2025 Rubicon 392, 2024 2-Door Rubicon X, 2024 Mojave X
I fly da plane...
WillysMeow
Corruptifornia
Bit wrassler
Do as I stated, it's very easy and the whole job took like 45 minutes including walking around the garage/driveway, petting kitty cats, sippin ma beer, rolling out extension cord and putting everything away lol.
Heimkehr
Pennsylvania
2021 JLU 2.0T
Other than this forum I’ve never seen anyone talk about the visor warning stickers! I’ve never actually noticed them on my vehicle until I joined this forum. And they still don’t bother me.
Same...and being as tall as I am, I should be the first to notice and be annoyed by the contrast of the bright warning stickers on the black sun visor. I'm not, though. The things that some people let bother them...
