Stop/start revisited. Need clarification.
plastrd
Michigan
2021 Wrangler Sport Altitude
A loose/corroded connection would have a similar effect as a bad battery as the high resistance would drop voltage during crank or other high drain situations.
I haven't had the issue myself but found one of the cables from negative to chassis ground next to the battery was barely attached and tightened it back down.
alphawolff
california
2021 JLU
Thanks, fully aware of your suggestions. I did try with nothing on etc….. always falls on battery protection mode after the first successful stop/start 🤷‍♂️
Replace both batteries. That warning directly indicates your batteries are under 65% state of charge. I do not care if they re-charge and "test" good. Replace them.
UncleJimmy
AZ
2020 JLUR; 2016 Toyota Tundra
ESS works in one battery too FYI. I deleted the lawn mower battery and put in new Odyssey H7. Everything works flawlessly. Having two batteries just complicates overtly unless you are doing a proper dual batt system which factory is not.
One good battery will keep everything working and if the voltage gets to low it will protect it and charge it at a higher rate.
Steph1
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
Was thinking that too, not arguing, but brainstorming….Where changing the batteries defy my logic is if the batteries are due to be changed, then why would ESS work on the first stop of a commute before “automatically” falling in “battery protection” mode and then when I re-enter the Jeep to go back home, ESS fires as it should on the first stop, and falls in “battery protection” mode again…. If I have 3-4-5 errands to run, it’s the same scenario everytime.
Batteries not being cheap, I don’t want to start throwing unnecessary money on parts that aren’t confirmed to be needing to be changed. I’d probably go with a bigger battery and cancel the secondary carppy one.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Because you’re maintaining a pathetically weak surface charge on the old worn out batteries with your charger, then it’s gone as soon as a minute load is put on them. Replace your batteries.
Terrymo
Terry
2023 JLURXR 3.6 ET
I tried this with a diehard platinum battery that had aged out and sat in my garage for two years. I attached a high end charger and put it on the “repair cycle” for a couple of days. Took it off the charger and hooked up my multimeter and surface charge voltage showed the “repair” was “successful“. My trusty Foxwell battery tester (falsely) showed the battery was “good“. Was it? Nope, sure as shit wasn’t.
autotragic
the cornbelt
'21 JLR 6MT
Just replace the batteries and be done with it. It'll solve your problem.
Bonus points if you aux delete the stupid thing and put a nice battery in it then you can have your ESS and not worry about the small battery depleting your main anymore too.
When you have two batteries in parallel then weaker battery will damage the stronger battery over time no matter what. It's advised never to run two different capacity batteries like Jeep does so why did Jeep do it? We may never know but it is always going to fail faster than one good battery.
Steph1
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
Thanks, that’s what I’ll do in the spring.
THAW
Foster
23 JL4DrRubicon
Does your Foxwell show CCA, SOC, SOH and resistance? If so, do you recall roughly what it reported?
I ask because I have a Foxwell that does and am wondering if I should be more skeptical of it.
