Auto Start/Stop re-starts during stop
tescatlipoca
Tes
illinois
Audi A4
I just got my 2021 Wrangler Sahara high altitude and I am wondering if anyone else has the same issue. When the car stops the auto stop kicks in and stops the car as expected however, during stop the car re-starts itself. Just curious if anyone else had the issue and knows how to resolve it.
Maverick909
Inland Empire
www.instagram.com
this is due to many things. check the message display in the cluster and it will tell you why. Typically if the A/c is on it will come back on to keep the cabin cooling or heating depending on temp. and it can be because of voltage drop and needing to charge the battery
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Wandering Vaquero
If you drive mostly short trips, less than 10 miles, your battery may not be getting fully charged. Take it on a trip of 20 miles or more every week or two. Also, the algorithms devolped for the start/stop sytem are complicated. Among the things factored in are engine temp, AC demand, steering angle, brake pedal pressure and battery voltage. If at times it restarts, or doesn’t stop running that’s normal.
Quinn99
Quinn
North Carolina
2021 Wrangler Sahara, Chief Blue
It’s almost always the AC. It rarely happens during the winter.
tescatlipoca
Tes
illinois
Audi A4
This may be due to AC. I will check. I dont know where to find messages in the cluster.
flyer92
Nevada
Agree 100%. Occurs in my JL and my wife's Cherokee all the time....no worries.
Maverick909
Inland Empire
www.instagram.com
use the right side up and down arrows on the steering wheel to scroll through the menus. i believe its menu number 8 or 9
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Um, the up/down buttons on the left side of the steering wheel, unless something has changed since 2019. Right side is the cruise control buttons. I was just playing around in the Tazer menus and those buttons.
jellis4148
Missouri
2019 Jeep Wrangler JLU Rubicon
Did your salesman not show you how to do that stuff?
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
It is brake sensitive as well. If you slightly let up on the brake it will restart.
AcesandEights
Aces
So. Oregon
2022 Jeep Rubicon 2D, with extra guacamole
@tescatlipoca Yeah, it's not an "issue", it's working exactly as designed. There are multiple reasons for it restarting, but all of them are part of the normal process.
Dgr401
Dennis
Rhode Island
2020 Wrangler JL Sport S - Granite Crystal
I have noticed this as well. I normally use the bypass switch but if I forget it seems that at the slightest movement of the brake pedal the JL will restart. It is very sensitive.
