Steering stabilizer talk
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
At 44k I'm finally experiencing some intermittent wobble. I'm obviously going to check everything but I'm assuming I will need a stabilizer. I'm sure Teraflex is great but I don't want to spend $400. The Fox 2.0 seems popular, is there anyone else I should consider?
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
Exact Center by Road Master is another one to consider… especially if your Jeep is a toad. Also not cheap but does a great job taking the wandering out of my 2dr. Contact Roadmaster to get the right amount of force for your vehicle.
jc1003
Jorge
Frisco Texas
2022 Sahara, 2025 Ram 1500, 2026 Hyundai Tucson Hybrid, 2023 Hornet
IT
I installed a rough country steering stabilizer and it feels way better than the stock unit. Didn't spend a lot of money either.
Tejas
Clint
Houston, Tx
'21 JULRD
Mine did the same at about the same mileage. After i changed the tires which were original, wobble went away.
Jeep Wick
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
I'm sure that's a factor too. I might rotate them again as I have more life on the rears.
Old Jeeper
Don
US Army Infantry, IT Engineer
Install NOW ASAP...
Lots of rube Goldberg and gimmicks out there.
I like the AEV SS.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
I've got the Bilstein, similar to Don's AEV.
One I would look at if doing a stock replacement is the Steersmarts HD-N.
EDIT: Note, the Steersmarts has a smaller bushing than some of the aftermarket relocation kits need, specifically synergy's.
Jeep Wick
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
I was wondering about Bilstein, I know they have a good reputation. How long have you had it and how do you like it?
limeade
Guy
Reno, NV
There's quite a few other parts which could need replacing before the SS. Before spending money on one, take it off and drive the same roads where you're getting the wobble. If it's still there, then your SS is fine.
The first two parts I'd be looking at when experiencing a mild wobble is track bar and ball joints. Both of these are notorious for wearing out quickly and causing mild to full blown death wobble. At 44k miles, your ball joints are more than likely wearing out. The stock track bar is a thin-walled piece of junk and should be tossed in favor of a quality aftermarket one, even if you're on stock tires.
Speed331
Sean
Las Vegas, NV
2008 Jetta, 2018 Discovery Sport, 2020 Wrangler Sport S (on order)
Another vote for the AEV Bilstein. It has a nice firm feel compared to the stock ss and does a good job smoothing out some of the 'chatter' that comes through the stock steering components.
I do agree with checking the track bar bolts/bushings as well as the ball joints. My track bar came untorqued at around 20k and ruined the bushings, causing all sorts of wobble.
Surprisingly, my ball joints are still solid at 60k miles- go figure.
Jeep Wick
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
Thanks for the tips. The roads where this happened are out of town and I'm not sure when I'll be over there again. I do like a good reason to buy upgrades, maybe I'll get a track bar on Black Friday. I'd be really surprised if it's the ball joints but I'll check it over this weekend.
limeade
Guy
Reno, NV
Don't be surprised.....mine were loose at around 16k miles with stock tires. Not enough to cause a wobble or shimmy, though it was only a matter of time.
Roky
Roky
I’ve changed these jl ball joints as early as 6-8k miles, they don’t always present a problem with the standard bj test…. I’m not sure why, although my theory is the plastic insert is tight enough when prying tire up and down, but not tight enough to handle 5-6k lb rig……
GATORB8
CLT NC
Had the Bilstein for a couple years, it's fine. Like other monotubes it's under pretty good pressure, I don't notice any steering push but may be due to weight and tire size.
That's one reason I'd consider the Steersmarts, it is balanced so no pressure in one direction, similar to the more expensive through shafts.
Jeep Wick
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
Well I ordered the JKS track bars also, decent price on ET and made in USA. Arrive Saturday, so early Christmas for my Jeep.
