Steer Smart Setup | Stabilizer ?
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
We are idiots. We thought it was threaded in and not that it could slide right out lol. Thanks for the help
Just went thru it, there are far stupider people out there than u. What mount are you using?
m3lover1
Ricky
Bay Area, CA
2019 Sting Gray JLUR, 2007 Yamaha R6
The steersmarts one for tie rod side and metalcloak relocation bracket on trackbar end side. I had that when I had my lift installed to relocate the stock stabilizer
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
verify the stabilizer fits on the metal cloak mount. The steer smarts mount on the trackbar side was to narrow for my fox ats and had to change to the synergy one.
m3lover1
Ricky
Bay Area, CA
It fit perfectly on mine. Btw did you reuse the fat rubber washer that was used on the original bolt from fox?
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
yeah. I used a rubber washer between bolt and stabilizer and stabilizer and mount.
m3lover1
Ricky
Bay Area, CA
Those that have the Fox TS Stabilizer just curious any rubbing between that and the drag link passenger side adjuster sleeve?
Jeep Wrangler JL Steer Smart Setup | Stabilizer ? 20200529_093652
Roky
Roky
You might try a synergy track bar/stabilizer bolt, the mc bracket sets the stabilizer a further forward.
m3lover1
Ricky
Bay Area, CA
@Roky and @Gdub , does your stabilizer sit flat with the yeti tie rod using Synergy's bolt? Mine is tilted in its natural position after installing the bolt. I could force it to sit straight with force, but atm I have it in its natural position. Picture shows it's tilted towards the diff side.
Jeep Wrangler JL Steer Smart Setup | Stabilizer ? 20200604_084329
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
mine sits flat.
Roky
Roky
Here’s mine, But it’s on a synergy tie rod might be slightly different than the yeti. I would let it sit like it wants to without forcing as long as it’s out of the way when flexing.
Jeep Wrangler JL Steer Smart Setup | Stabilizer ? 73506382-CB4C-4CCC-A40C-135B0F4F1DC0
