Start stop battery dead again??
kapk22
Kasey
San Antonio Texas
1990 YJ, 2021 JLUR
I just got the error message
“Stop/Start Unavailable
Service
Stop/Start
System”
If I remember correctly, this indicates the auxiliary battery is going bad again. I replaced it in 2022 and have a tazer mini. The start stop has been disabled since 2021. Is the auxiliary battery dead again after 4 years? Even with the start stop disabled?
This is a 2021 JLUR with the 2.0
alphawolff
california
2021 JLU
Service
Stop/Start
System”
batteries do die naturally
WillysMeow
Corruptifornia
Bought my first new Jerp! :)
Bit wrassler
Free, search around here there are a couple threads on it, easy to do. If main battery is bad, you'll need that replaced either way.
kapk22
kapk22
Kasey
San Antonio Texas
1990 YJ, 2021 JLUR
Does anyone know if there is an easy way to test each of the batteries separately?
I would think they could isolate the wires that go down to the auxiliary battery
alphawolff
california
2021 JLU
Estimated cost?
free.99
if you're keeping both you always replace as a set. but just disconnect both leads off the negative terminal and you isolate the primary
kapk22
kapk22
Kasey
San Antonio Texas
1990 YJ, 2021 JLUR
free.99
Okay. Based off what I am reading, it looks like all that is need to delete the aux battery is taking each of the terminals off and taking them up. I would guess the main battery is also going, if the auxiliary battery is. I just didn’t want to go and buy a battery (or two) if it was something else going on. That’s why I was asking about isolating them. If I do the delete and the main battery is still good, I will just be out the time. Crossing fingers
Thank you
alphawolff
california
2021 JLU
Thank you
just take n3 off the PDC and run a jumper between n3 and n1. disconnect the aux negative at the primary negative. done deal
AndySpill
Andy
Pittsburgh
2018 JL Sahara
@kapk22
Testing the batteries should be done with a load tester, not a multimeter. To test the main battery pull all the cables off its negative terminal and place your load tester on the battery.
To test the Aux battery move the load tester's negative lead to the cables you just disconnected from the main battery's negative terminal, leaving the load tester's positive lead on the main battery. This will test (only) the Aux battery; yes, even as the load tester's positive lead remains on the positive terminal of the main battery, because the only circuit formed is with the Aux battery.
Reconnect those cables after you are done.
To take the Aux battery out of the vehicle's electrical circuitry disconnect the cable on the main battery's negative post that is connected to the Aux battery and tape it up. Which cable that is can be found here: https://www.jlwranglerforums.com/forum/threads/ess-battery-cable-change.86624/
Then open the fuse box cover and pull fuse 42. Turn ESS off on the dash or with aftermarket tech to do that for you (e.g. JL Tazer, Auto Stop Eliminator.)
kapk22
kapk22
Kasey
San Antonio Texas
1990 YJ, 2021 JLUR
@kapk22
I’ll see if I can stop by advanced after work today. Hopefully they can see what’s going on. Jeep has to start every day this week. Trying to get a new thermostat in my old yj so I have her as a backup
