speedometer difference
BBDOC
Victor
BMW 5-Series, Honda Civic, Honda Minivan
Agree. Crazy. Who do you believe?
AggieJeepGuy
NW AR
2018 JLUR (replaced 2007 JKUR); 2016 Durango Brass Monkey edition; 2011 Expedition; 2002 Trans Am WS6 6spd
Noticed what seems to be a pattern on mine. To be candid, I usually only drive a few miles each way to work so I haven’t had a long drive to validate the scenario. However, it seems that mine is primarily off in the morning when I first drive (and it’s cooler?). Then in the later part of the day (warmer?) it seems to be spot on. I have seen this at least 3 times now and was finally able to document it. What you can see is when it’s off, the dial does not drop to zero and reads over by roughly the amount it’s above zero. When it’s accurate, it will read true zero at a stop. The timing may not be related and just coincidence, but I’m certain the zeroing piece is the key to it being off. Root cause of the zeroing issue???? See pics
Jeep Wrangler JL speedometer difference 636CFF1F-96BD-4151-9ED1-019FFED93B18
Jeep Wrangler JL speedometer difference 24EF1B3B-5270-4757-95BE-3742055964BE
Jeep Wrangler JL speedometer difference D3EDD8AF-BF2E-4320-BB6A-14C38B2D5F0A
Jeep Wrangler JL speedometer difference BB03F6D6-7A99-4802-BAD1-2A79728C6E3D
frostai
Tristani
Puerto Rico
JLR
My JLUR has only 3 months and I started noticing it on the highway and then on some stoplights ranges from 3-10 mph, but today I noticed that it got stuck at 10 MPH on idle when I had a sudden stop and the Jeep's autostart turned it off before the marker hit 0.
Dunno if that's the cause, but posting to see if you guys can do a test and post back
Jeep Wrangler JL speedometer difference ab013bb4-844b-4fb5-9380-7e0bc8b2097
Jeep Wrangler JL speedometer difference 86da81ed-6278-412e-bfa0-17bfcdf342d7
jebjkey
Hawaii
Wrangler JL Unlimited Sport S
I got my gauge cluster replaced, but not because the speedometer needle was off. I was the RPM indication that did it in. I initially took mine in for the speedometer being a few MPH off, Jeep's response was that that is normal and no repair required. :movember: When I took it in with both RPM and speedometer problems (and a Jeep Cares case number) I got a new gauge cluster. The new cluster is spot on for both speedometer needle and RPM. :)
JeepCares
Auburn Hills, MI
JL
Hello frostai,
We're sorry to hear about this concern. If you end up going into the dealer, let us know. We're available via direct message and would be happy to help with that process.
Jasmine
Jeep Social Care Specialist
wb880
Nevada
2021 Unlimited Rubicon 4XE
My cluster was replaced by my dealer when I showed them a few week worth of pictures of my speedometer off from the digital speedometer. Mine would jump 1mph every drive cycle and then randomly reset.
The new cluster has been perfect since the replacement.
D-Mo
Daniel
Virginia
2018 Wrangler JL
Also heading to the dealer in the next few days for a new cluster. Having the same speedometer issues and my odometer shows 999999 randomly on startup. Drive for a few miles and it goes back to normal...
JeepCares
Auburn Hills, MI
JL
Hi D-Mo,
Glad to hear you have an appointment with your dealer. There's actually a STAR case open for this and your dealer should have access to the details. If you have any questions you can send JeepCares a private message.
Lydia,
Badboylopez
Jerry
Austin
2018 Jeep JL Rubicon
Jeep Wrangler JL speedometer difference 9983EB38-9375-43B3-B419-48FA64D201B5
Jeep Wrangler JL speedometer difference 9D342288-59BB-4DFC-BF28-3D903651DAD5
I have a Jeep JL Rubicon and just noticed it’s doing the exact same thing as described.
TimmH
Timm
2018 JL Wrangler Sahara 3.6 Auto
Full stop showing 6mph
The real question is, "does it accumulate miles while sitting still thinking it's doing 6mph"? *LOL*
Cajun
Alabama
2018 JLU Sport
Don't doubt for a second that it didn't cross my mind! Dealership appointment Saturday for what they say will be a recalibration ... Will keep you posted
