Speedometer Gauge Incorrect
amckinney
Andrew
2018 Jeep Wrangler Unlimited Rubicon
Is anyone else having issues with the speedometer gauge randomly being incorrect by +1-15MPH? It seems to randomly increase by about 1MPH each start until it randomly resets back to 0. The only way to know my true speed is to either have the digital speedometer on the dash, or notice how many MPH the gauge shows at a stop and then subtract that from the current number at speed. I figured that an update would eventually fix it but it doesn't seem that will happen.
Note: This is stock wheels/tires.
W1ck3d
Toledo
2019 jl rubicon
Make sure you didn't accidentally switch it from mph to km... Other than that might be a bad cluster
W1ck3d
Toledo
2019 jl rubicon
On 2nd thought it maybe a wheel speed sensor going out...
catdaddy63
Karl
Tulsa Oklahoma
2018 JLUR Ocean Blue, 2017 Fiat 124 Spider Lusso
Used Car Manager/Buyer
There is a cluster flash to fix this issue, mine would be up to 5 mph higher on the analog and it would not go to zero when stopped. Flash took care of the issue for me.
amckinney
Andrew
Thank you, I will run it by the dealership. Every other time I have taken it in, they have wanted to keep it a week and nothing gets fixed. Good to know that there is an actual fix.
amckinney
Andrew
I would think that the analog and digital pull from the same wheel sensor, but who knows.
catdaddy63
Karl
Tulsa Oklahoma
Ask them to perform TSB 08-108-18 REV A, it's the flash that you most likely need.
Quake LED
