Deleted member
Guest
S1808000278 fixed it for me too!Check my re-post/update as the Technician obviously fat-fingered the Star Case Number as he missed an extra zero and s/b S1808000278.
The following fixed my speaker rattle (alternative option, but similar to other fix listed in the post above).
Original source of info, thanks DaveK: https://www.jlwranglerforums.com/forum/threads/charlie-brown-audio-sound.17229/#post-426005
1. To replicate the problem visit this youtube video, plug your phone into the aux in audio port. It will play a 145 hz tone for about 1 minute. You have keep hitting replay because it is only 1 minute long.
2. In the uConnect audio setting change it to back right, back left, right front to hear how it should sound. Change it to the left front and BINGO! super rattle kicks in.
3. Next to the ODBII port, you will find a few connectors (see picture below). Tap on the cable harness coming from each one until you hear the rattle sound go in/out. Then isolate to which set of wires. Push that set of wires up slightly, hold it, rattle goes away. Get a cable tie to hold it in that position. Done!
Picture below is from DaveK.
Same!!! Horns up!I am effected by this as well... pretty much can't play Metallica in my Jeep, seriously annoying!
