EndiSky
Are you getting a vibrating sound from the area of your left knee? It is NOT the speaker!
There are 2 plugs that have a loose connection and vibrate on certain frequencies. This, for me at least, happens when the stereo is playing talk radio/ podcasts with a deep voice.
There are multiple fixes out there spread across quite a few threads, but this worked wonders for me and only took about 5 minutes (including taking pictures!)
Step 1: Identify the problem
The "Charlie Brown Adult Voice" issue that I and many others experience may be what you have, it many not be. Here is an easy way to check.
Download a free Sonic Frequency Generator app for your phone. The one that I used is called "Sonic Sound Wave Generator with all Tones" from the Android app store. There are many out there available for both Apple and Android, its up to you.
Connect the phone to your however you normally would, bluetooth, usb, 3.5mm jack, whatever.
Have the app play a tone of around 145hz, doesn't need to be exact, just close.
Before taking anything apart on your dash, stick your head under the steering wheel area (probably not while driving!) and listen for intense vibration, NOT the tone, but vibration... you'll know, trust me!
If you've got the buzz, move on to Step 2, if you don't, go drive through some mud!
Step 2: Locate the culprit
Beneath the steering wheel, there is a panel that is about 18"x18". It is held on by 6 clips and is removed by pulling on the area of each clip until it pops off. See below for clip locations:
Once this panel is removed, you'll want to look UNDER the dash in the general area behind the yellow squares in the next photo:
Underneath you will see 2 plugs, each with one bundle of wires coming out of it, these plugs are where the vibration is coming from!
Retest with your sound app to be sure. Play the 145hz sound through your stereo and see if poking and prodding this set of plugs stops the vibration.
Here is a closeup of the plugs you'll be messin' with:
Step 3: Fix it!
Others have used epoxy to secure the plug better, some have stuffed business cards in between the plugs and the housing, I chose to go with my handy dandy zip ties.
Placing a zip tie around the wires and the metal bar underneath places enough tension on the plug to keep it from vibrating. See the above pictures or the one below, please note that the wire bundles are NOT yellow! I've just colored them for you to know the AREA to look for 'em!
Step 4: Wrap it up
Make sure that you're issue is solved, and CUT THE END OF THE ZIP TIE OFF! Close everything up and have a beer, you deserve it!
Step 3: Fix it!
Step 4: Wrap it up
