So, I just noticed this...
JeepChicNJ
Ami
Jersey Shore
2022 JLU Tuscadero 2024 JLU 4xe Hydro Blue
I've had this Jeep since February, driving today when in "D" the gear number is also there 🤔
I feel crazy for asking!!!
Jeep Wrangler JL So, I just noticed this... IMG_20240528_120913
2024 JLU 4xe
Bryce
Bryce
Acworth, GA
2019 JLUR
there is an option in the screen set up to display what get it is in all the time.
  1. With the Jeep in park, go to screen setup (page 9) on the screen between your gages.
  2. Press OK
  3. Scroll to the one that says Current Gear and select it to on.
Reinen
2021 Jeep Wrangler JL Rubicon
You don't necessarily need to be in manual mode. You can have the gear displayed while in Drive in the options menu. I find this very helpful and always have it displayed.
ArcadeTracks
PJ
Pittsburgh, PA, USA
He (and the OP) has different fonts than I do! Maybe because it's a 4xe?
Heimkehr
Pennsylvania
2021 JLU 2.0T
I've the monochromatic TFT screen in my JLU.
When using the AutoStick feature, a single numeral will be displayed, indicating the current gear selection.
When in Drive, a D paired with the current gear in subscript (i.e., identical to what's pictured in the OP's post) will be evident.
JeepChicNJ
JeepChicNJ
Ami
Jersey Shore
  2. Press OK
Thank You!
I wasn't messing with my settings at all, I did scroll through tho.
Mike_Hawk
Illinois
2022 GOBI JLUR 3.6
Mechanical Engineer
You're in 1st gear. Your shifter has been tipped to the left and you're in manual mode. Lol
Hopefully, your weren't going too fast.
The computer in the jeep won't let you shift into gears that can damage the vehicle, it just straight up wont shift if it shouldn't
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
It clearly shows that it's not in manual mode. You might be confused.
Dryver
NE Ohio
2021 Wrangler 4xe "Bridgette"
Thank You!
My 2021 4xe displays the current gear like this and I didn't change the setting either. I think this is the default.
mark090852
Colorado Western Slope
2020 Jeep Wranger Unlimited Rubicon
Definitely not in manual mode. The "D" indicates it is in auto mode and the small 1 next to the D indicates the transmission has selected 1st gear at this time. It will change as the transmission changes gears automatically. It's a setting you can change if you don't want to see the gear number. It will just read "D' then.
