Simple Subwoofer Upgrade!?
JasonInDLH
Jason
MN
21 JLUR, 15 Yukon Denali
I’d Rather Talk Jeep’s!
And you don’t need to remove the fender liner like I did (I removed it in attempts to find a good mounting location for my battery tender). Just drill from inside the cabin.
You can then sit on a small stool and reach inside the liner and reach inside the cabin at the same time.
Nater34
Clint
2021 Wrangler 392
Ooh, you actually drilled a hole!? Some folks I saw seemed to find openings to run in.
JasonInDLH
Jason
MN
Yeah…I drilled my own hole. I really liked the location. With a good step bit it was easy.
JasonInDLH
Jason
MN
@Ghostwolf …I saw a thread that there is a good power wire entry point on the driver side (shoot…I cant find the thread now), but that will probably be better for you than the passenger side since you’ll be installing the Kicker HS10 under the driver side seat (correct?).
mrtm1970
Marshall
Orlando, FL
2019 JL Unlimited Rubicon
Mechanical Engineer
I found it ???
It is a plastic twist out (though I just drilled a hole through it)
Jeep Wrangler JL Simple Subwoofer Upgrade!? 6C54340E-C0AD-44ED-B1B4-6F6F9E081B95
Jeep Wrangler JL Simple Subwoofer Upgrade!? FF240225-B065-487F-A4ED-5C94061A96EE
Jeep Wrangler JL Simple Subwoofer Upgrade!? 217EF4EE-49A3-498C-B3D5-3360EED8DE0F
Was stated that this is not available if you have a manual transmission so assume it is there intentionally for something when you have a manual transmission.
Ghostwolf
Ghostwolf
Brooklyn
2018 Jeep Sport Unlimited JL
Oh man . . . Been crazy busy (which is good, keeps me out of trouble) - so, lots and lots of research and vids and tutorials but still no luck on a solid, informative set of instructions or process on installing a Kicker 46HS10 hideaway into a Jeep JL . . . Some "okay" write ups and discussions but still very confusing and conflicting information! Really wish Kicker / Crutchfield or anyone, at this point, would produce a solid install vid!!!!! Ugh!!!!! Still confused on blue wire auto on/off (one discussion was attaching it to the 12V in the center dash and others don't connect it at all) placement of powered sub itself (under passenger seat ideally but finding that to be an issue and definitely not under rear seats, maybe make a behind the seat neoprene holder, using the sleeve storage of the seat and some carpet covered wood and straps, IDK?) and tapping into the B pillar (sound bar "rear" speakers) . . . Just . . . Ugh . . . And mother nature ain't helping!!
Nater34
Clint
2021 Wrangler 392
You don’t need the blue wire. The sub will turn on when it senses the signal from the wires in the pillar. I only connected power line to aux cable and then spliced into those speaker lines and then ran the gain control knob up front.
Ghostwolf
Ghostwolf
Brooklyn
And I set the powered sub to DC?
JasonInDLH
Jason
MN
Yes…choose DC as opposed to 12v on the amp. Just put some electrical tape (Super 33+ is the good stuff) or adhesive lined heat shrink at the end of the blue wire and coil it up out of the way. Or cut it short and do the same as above.
Ghostwolf
Ghostwolf
Brooklyn
Now the pos / neg tapping into B pillar . . . Do I splice the B pillar wire, expose the inner wiring (by removing outer tubing), twist appropriate exposed wires together and stick the twisted wires (2 wires twisted together - one being the B pillar wire, the other being a wire from the powered sub harness) into one end of a crimp connector and then the single exposed wire (the other end of the spliced B pillar wire)? Basically, it looks like an upsidedown Y (2 wires twisted together - B pillar wire, pos or neg, twisted together to power sub harness wire, pos or neg) leading up and through to the rest of the B pillar wire? I'm sure there are dozens of ways or get T taps and those flat connectors?
JasonInDLH
Jason
MN
One thing that I recommend when attaching the HS10 is that you go to Home Depot, Lowes, etc and get a bit of 3/4 MDF to adhere to the floor board (under the carpet). I always use quality caulk and apply liberally (after cleaning the area well of dirt, grease, etc) and let set for a day. Reinstall the carpet. Then use a course thread screw to attach the unit to the MDF instead of into the floorboard.
Not only are you protecting your floorboard (and possibly drilling into something important underneath), but your reducing the risk of ground loop noise as well.
If you choose to place it under a front seat, make sure you have clearance for the 3/4 MDF and are still able to slide the seat back and forth.
I didn’t place my amp under the front seat since the vent would blow right on it (I did think of re-routing the vent, but decided not to). I know others have installed amps there and perhaps it’s not an issue?
JasonInDLH
Jason
MN
Definitely don’t do any quick connector like a T-Tap, Posi-Tap, etc. Those are good for temporary usage.
A butt connector works well. Make sure it’s the correct size for two wires coming into it. If you look closely by my fingers you can see both wires coming into the connector. The other side I also have two wires of the same size (so you get a good crimp), but one of the wires I cut short (you can see the lump under the heat shrink)..
Jeep Wrangler JL Simple Subwoofer Upgrade!? CB3474EF-98B4-404A-8729-D024BED4E72C
Ghostwolf
Ghostwolf
Brooklyn
I've been drawing up ideas in my head for weeks now on that very concept and have done a deep dive into "removing passenger seat Jeep JL" on YouTube and Google and have found absolutely fucking nothing!!! NOTHING!!! To help navigate or help brainstorming for ideas of seeing what the floor board and terrain looks like under the passenger seat but again, nothing!! Yes, some shitty vids of fuck-all jagoffs, with crappy presentation and hosting skills and some crap-tastic lighting and botched instructions and tutorials. But seriously!? And they are sponsored vids too . . . Disappointed and depressing . . . Why is this like trying to capture a unicorn impossible!? Probably cause all the unicorns were already slaughtered in my vehicle (still finding glitter and chocolate syrup on things)!?
Ghostwolf
Ghostwolf
Brooklyn
Right on - so 2 wires into one end of the connector and then it continues up and through to a single wire on the other end (left pos to left pos twisted and left neg to left neg twisted...and so on)?
