Complete Audio System Upgrade
jcardenas7196
Joaquin
Chicago
2019 Jeep Wrangler 4 Door
Installing new audio system into my 2019 JL Wrangler. (4-door). Hifonics Brutus amp for two JL 12" subs. JBL 4 Channel Amp for Speakers. Upgrading the Roll Bar speakers from 4.5" to Focal 6.5". Upgrading Knee Speakers from 4.5" to Focal 6.5". Upgraded dash speakers to Kenwood 3.5". Kenwood Excelon 6.5" touch screen radio. About $1800 for everything. Looking forward to the project ahead of me but I will update you all with the quality of the sound once I am done. Looking forward to go topless soon.
1st Update:
Upgraded 4.5" roll bar speakers to 6.5"....recommend using crutchfield for purchases. Bought the adapters to make my new speakers plug and play basically. You will need to remove the roll bar and do some cutting. Took me about 3 hours total. Here is a link to the thread that I used that pretty much had all the info I needed...
https://www.jlwranglerforums.com/forum/threads/jl-soundbar-removal.11961/
Also upgraded the 3.5" dash corner speakers for the Kenwoods, that was simple. Just pop off the grill, unscrew the original speakers and plug and play your new ones. If you need the adapter they are listed as Metra 71-039C Speaker Wiring Adapters - Front.
I created a custom subwoofer box for my two 12"s. Forgot to take a picture of the finished product but I will add it later. This is what it looked like at some point in the process. It is a sealed box that sits perfect in the trunk limiting the amount of cargo space it takes up. Took about 7-8 hours to finish. Love the end result, I will post a picture later. Looks great and clean...but you need to be handy with a saw and some carpentry knowledge will help.
I have been tackling this project in pieces because I am still working. Next part will be in install the speakers with the amps, won't be using the car for a while so won't have to worry about finishing it all in one sitting.
2nd Update
Finished building the custom box.The entire process took about 10 hours. The 12" JLs sit a bit recessed inside the box for a smoother look and greater seal. Next update will involve putting everything in the car now.
3rd and Final Update
So I finally finished everything after about 50 hours of work. Final pictures below. It sounds loud enough that you can hear it more than a block away but so clear that its like you are front row at a concert. I enjoy cruising with loud music so this is exactly what I wanted. This is probably more than what the casual listener would want but still phenomenal sound.
1st amp with 2 crossovers for all the front speakers and front tweeters under passenger seat
I had to take out the speaker casings from the knee speakers to enlarge the opening to fit the new 6.5s.
Two crossovers for rear speakers and tweeters
The tweeters really give the sound the high pitch quality.
The Kenwood and the corresponding frame really give the dash a smooth look.
Hifonics Amp for the Subs is actually in the storage in the trunk.
It was a long build but after everything, it was well worth it. Used Crutchfield for most of my purchases.
Not Pictured:
We had to drill a hole in the frame of the vehicle in the front passenger side under the glove box to run the power wire to the battery. Did it next to the existing clip that holds the carpet.
MikelMD
Mikel
Maryland
2020 Punk'n JLU
Principal Sales Engineer, Public Sector
Looking to pull the trigger on my new system. Pls add any links to videos, how to's used, or pix in process. I shall do the same.
goose77
Chicago
2018 JL, 1986 CJ Laredo, 2018 ROXOR street legal
Very interested in how this turns out. Please keep us updated
Gonz
Andy
St Paul
2018 JLU
Gym Owner
Very cool. I'm in the middle of the same project, be sure to post updates and pics in progress so we can all see how it goes!
jcardenas7196
Joaquin
Chicago
Updated the original post with what I have done so far...will update later with some more.
jcardenas7196
Joaquin
Chicago
jcardenas7196
Joaquin
Chicago
jcardenas7196
Joaquin
Chicago
1st Update:
2nd Update
Let me know what you all think of the custom box! Will put into the truck tomorrow hopefully.
jcardenas7196
Joaquin
Chicago
1st Update:
2nd Update
Not Pictured:
Final Edits have been Done!
ToPar9
North Texas
'19 JLU Altitude
I didn't think about mounting the crossover under the seat. I mounted the components as far forward as possible on the side kickplates. This pic is on the passenger side.
Under the front passenger seat, ran the cables under the carpet.
2.5's and tweeters on the dash
Your build is looking good!
emgeesea
Marc
Portland, OR
2020 Willys
1st Update:
2nd Update
Not Pictured:
That's some project! I also opened up the sound bar speakers to 6.5" coaxials using the SVV adapter, but I'm a little underwhelmed with the sound. I'm wondering if you had to do any tuning to get the sound bar speakers to sound right? In particular, I'm wondering whether the rear gain on my Alpine KTP-445U amp that powers those speakers needs adjustment from the setting I've used with the factory components that were in the sound bar?
Any thoughts? I'm not all that knowledgable re: amps and speakers!
ToPar9
North Texas
'19 JLU Altitude
Pack the speaker pod with polyfil. I packed all of my pods with polyfil. Not sure if it works, but I’m happy with the sound.
The soundbar speakers are for fill. I threw in some cheap kicker 6.5 2-ways. They are loud, works well for what I’m looking for. My fronts are 3-way components that supply the highs, with a little bump in the knees.
it also depends on the speakers you put into the soundbar.
emgeesea
Marc
Portland, OR
2020 Willys
Thanks. I still wonder whether the gain setting on the amp needs to be adjusted for these speakers. I’m going to call Alpine tech support, since I used Alpine 6.5s in the roll bar, and see what they say. I went with their R Series coaxials, which are not cheap speakers; they should sound great.
jcardenas7196
Joaquin
Chicago
Yes, you should definitely tune the amp and radio to adjust for the new speakers. Usually everything is set up to handle the stock sound, so you should always adjust when you add anything,
jcardenas7196
Joaquin
Chicago
That is a good spot for the crossovers I should have looked at in hindsight. Nice work!
TopLift Pros
