shocks leaking or weeping?
JP52
Walnut Creek, CA
2022 JLU Rubicon XR
I was crawling around under my jeep and I noticed a little oily residue on both of my rear shocks and a bit less on one of my front shocks and I'm wondering if this is normal or a problem. A little internet searching suggests it is normal for shocks to "weep" a little. This is on a 2022 JLUR XR with 14k miles. I have attached a picture of one of the shocks. I'm thinking to just wipe them off and see how long it takes to get covered again.
Jeep Wrangler JL shocks leaking or weeping? oily shock
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
No, it's not normal for shocks to weep oil. The rod seals are no longer doing their job. The leaking rate will increase with time, and sooner or later the shock will lose enough oil to function properly. Also, as the internal oil level drops, so will its cooling ability.
Valpo Jeep
Doug
Valparaiso IN
At 14k they should still be under warranty so go see the dealer. Insist on having them done in pairs, front or back.
Megawatt
Sin City aka Vegas
money pits: Turbo Busa, Street Bob, 22JLUR snazz, 5.0 mustang MT
Powerplant operator
Jeep Wrangler JL shocks leaking or weeping? E2940D6D-1135-4F5B-B7E8-9236B0F04F27
Get it replaced. Mine didn’t even make 7000 miles and was replaced.
tk1700
Tom
New Mexico
2021 JLUR, 2016 Tundra, 2025 Hyundai Palisade
I've had all 4 shocks on my 21 JLUR changed because of leaking. Mine were a bit worse than what what your pic shows. The rears were done about 15k miles and the fronts at 25k miles. I didn't have any issues with the dealer replacing them. The rears took 2 trips because they had to order them. The fronts were changed same day I took in. Good luck!
Electrified
2022 392XR
I inspect my shocks (among other things) regularly. If/when I see them leaking, I will convince my wife of the need for new upgraded shocks. :CWL:
HHIJL
KT
Hilton Head Island SC
2022 JLU Willys Xtreme Recon, 2018 Shelby GT350
HHI Fire Rescue Fleet Manager
My 2020 front shocks started leaking around 6000 miles. I figured if I had them replaced under warranty, it would just be the same thing again, more leaking factory shocks. I went ahead and replaced all 4 with Fox shocks.
JP52
JP52
Walnut Creek, CA
2022 JLU Rubicon XR
That's not a bad idea, but I'm thinking about getting a lift after the warranty runs out so I'll keep them stock for now. With 14k in only 6 months it shouldn't be too long of a wait.
Industrialwrench
San Diego
08 SRT Challenger. 18 4Runner off-road premium.
Mine weep when I drive it off-road at decent speed. Getting them super hot seems to do it. If I wipe them down afterwords they stay clean on the road till I romp it again. The factory rubicon shocks are just not made for extended desert use.
Smoke Showing
South Jersey
2018 JLU
I had 2 go at 30k. I didn’t care about being covered under the warranty because this was was in my living room.
Jeep Wrangler JL shocks leaking or weeping? E828D2F8-478B-422F-8783-0997A6FD9EE9
