sjappers
It should not be hard to put in 4hi, 4lo yes...but not 4hi? I think I heard you can shift on fly up 50mph?That info would be in the owner's manual. Give it a read. Same thing with the info for 4L.
The owner's manual will let you know at what speed you can safely shift into 4H and 4L.It should not be hard to put in 4hi, 4lo yes...but not 4hi? I think I heard you can shift on fly up 50mph?
Considering how the Shift lever on the 99 Cherokee is in a recessed part of the console, and has an entirely different shape than the Automatic transmission lever, its easy to not mistake the two from each other. Likewise with the 2010 Wrangler, they're an entirely different shape. The JL on the other hand, well they're both round and right next to each other, and if you have someone not paying attention I can see someone grabbing the 4WD lever trying to go from R to D when they're pulling out of a parking spot. Kind of a redundant safety I believe.I have to chuckle when people say accidentally putting it/bumping it into 4wd. My daughter has a '99 Cherokee and my other daughter has a 2010 Sahara. They both shift very easily into 4wd but you'd have to be doing an incredibly crazy Yoga pose to accidentally bump them into 4wd if it were even possible at all to do it.
It SHOULD loosen up a bit over time as you use it.If this Jeep didn't make my wife incredibly happy and she didn't have 5 of her 7 neck vertebrae fused thereby making it impossible for her to have the strength to shift this thing into 4wd, I'd find your comment humorous.
It's very aggravating that she finally has her Jeep but they have made this thing so stiff to put into 4wd that she can't do it. It's not like we are going to sell it but it definitely is a downer. I plan on trying to put it in and out of 4h on a regular basis to see if I can get it to break in and loosen up.
I wondered if the axle disconnect had something to do with it.
We just recently picked up a JLUR and I have to agree that it was a little tight getting the transfer case to cycle through. I would assume that over time it will "break in" and become easier, but it was a little hard to get into gear initially on our 36 mile Rubi...Finally got my new JL Sport! Having previously owned a Cherokee Trailhawk (4wh kicked in automatically) and a Liberty (would flip a digital switch), this is my first Wrangler (Command-Trac). While 4h works great, it takes a very hard pull to get it into 4h. Is this normal for Wranglers or should I be concerned?
This is my first post but I've lurked on the forums here for a while. Thanks for the help!
