Service DEF system
Ruby Mike
Ruby Mike
Southern California
2020 jeep wrangler diesel
Once I opened the DEF tank filler and let it set a while, the error code went away. Today, the CEL also cleared. Lesson learned, if you completely fill the tank, bleed off the tank by allowing it to fully vent. Thanks again for everyone's advice and help.
Ruby Mike
Ruby Mike
Southern California
The dreaded service def system just popped up. This time I have about 1/3 tank full. The CEL is on. So I guess Monday in it goes.
Capricorn
Las Vegas, NV
2024 JL Willys XR V6
Network Architect & Engineer
Sorry to hear that. Keep us posted and good luck.
Rangemaster
Nevada
2020 JL Rubicon Diesel
Business Owner
Mine just came on at 4000 miles. What did they do to fix it?
gburchett
Greg
Whitesboro, Texas
‘22 JLR, Sting-Gray, ‘15 Ford Fusion, ‘16 F450
I filled the tank to the neck. The code popped after about 200 miles. I opened the DEF tank cap a couple of times. I have filled the tank before and never had any problems.
Don’t tell the dealership you filled it to the top. I have a F450, and I remember reading somewhere, not sure if it was the manual or somewhere else, that you should only fill until the nozzle clicks if you used gas station to fill it up. I think it has to do with the vent. I belI’ve it will get clogged either by the DEF or it will crystalize in the vent and block it. If you can, I would try to suck some out to get it past the vent.
rickinAZ
Phoenix
2026 MOAB 392
As a tangental point, I don't completely fill my DEF tank for fear of spoilage - especially in a Phoenix summer. Do you guys have similar concerns? [but, then again, I only drive 5,000 miles/year.]
NewbJLUOwner
JLU Rubicon Diesel 2022
Watching ?
Please update when fix has been completed, what was done etc
Mileage, also
Sorry to hear this is happening
ALK
Adam
Arizona
2022 Jeep Wrangler
You're going to have constant issues with that system, especially if you don't drive it very often.
Ruby Mike
Ruby Mike
Southern California
I vented the DEF tank by opening the cap and let it sit a while. Later I got down to 25% DEF and the CE light came on. I took the jeep into the shop and they did a recall on the DEF system. That cleared the code. Bottom line is the jeep don’t like the DEF tank to full or low.
rickinAZ
Phoenix
2026 MOAB 392
Huh? Zero issues (constant or otherwise) after two years.
And...it'll pull your house off its foundation, basement and all. :)
ALK
Adam
Arizona
2022 Jeep Wrangler
Can’t leave us hanging on the details. Do you drive short distances and have had issues in the past?
I deal with Exhaust treatment systems & DEF every day, the stuff is just plain nasty & eats at everything it comes in contact with. Everything with the after treatment system needs to be worked on a constant basis, it needs heat to do it's job correctly.
Rangemaster
Nevada
Business Owner
Well, I got a appointment for next tuesday to have them look at this issue. Had to remove all the skid plates today. What a PITA to do by yourself. Now she is running with no underwear. Next to remove the Taser and Pedal monster, which is another PITA. What we go through with having our jeeps worked on.
Wrangler man
Howard
Palm Springs
2020 JLUAD
California desert, Follow the same protocol. Seldom fill past half. Funny how anti diesel Wrangler people complain so much about def. It's a national diesel thing on all modern diesels.
Commercial operators seem to have manage and have accepted the change. But some Wrangler folks seem self entitled.
Compression-Ignition
Roy
Montana
'22 JLUR 3.0 Diesel, '20 6.7L F350, '94 12 valve
Our new to us 2022 just popped this message. Ultimate fixes/repairs? Also It's been a while so I very well may be misremembering, but I recall there was a DEF gauge that I could access somewhere. I went through all the screens (seemingly) and I don't see one.
And the DEF cap at the fill tank is a plug instead of an outer cap. I recall it being a cap that would click when closed? But I could be thinking of my other diesel vehicles...
