Service 4wd light
Jmccord
Oregon
Jeep JLU
Driving down the road "service 4wd light " flashes on than off . Does not stay on longer than 3 seconds. Sometimes less than a second. No lift. Stock height. 33in tires. No hard-core wheelin. Any ideas?? No check engine light either
Bill_BCNtoNY
Bill
NY
Ocean Blue JLU Sahara 3.6
Advisor to Boutique Consulting Firms and Solo Practitioners
if you’re lucky it can be a dirty ABS sensor. Super easy to access, clean and remount!
give it a shot and let us know
Bill_BCNtoNY
Bill
NY
I'll check that out thanks. I've checked all the fuses already also
while you’re there, make sure whoever touched them last installed them properly in the rear - one of mine was run incorrectly in a way that put a tension on the wire
At Risk Ute
Christian
‘23 392 XR
Retired Navy
Try pushing down on all your fuses. Light is coming in 2H?
At Risk Ute
Christian
‘23 392 XR
Retired Navy
Yes 2h. Normal street driving
Does your transfer case have 4H auto? Maybe leave it in that and see if it stays long enough to visit the dealer.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Nope. 2h/4h/ 4lo. 2018 JLU Sport
You're not going to make any headway whatsoever without pulling DTC's from the DTCM/TCCM.
A wheel speed sensor will cause ABS/Stability Control/4wd/CEL to come on, your problem is something in the 4wd system like a FAD actuator circuit fault, or transfer case position sensor fault.
bcupton
Bob
St Louis Mo
25 Wrangler Rubicon X
Retired Navy
Mine had to have the wire replaced and that fixed it.
Anth6ny
Anthony
Charlotte, NC
2020 JLU
There are hundreds of variables. Your best bet is to buy a Bluetooth OBD scanner on Amazon and download jscan. You can run the codes and see exactly what’s happening. It could be a wheel speed sensor (ABS sensor), a transfer case sensor, a FAD issue, or a transmission issue. It could even be mismatched tire sizes. Just run the codes and it will make diagnosis much easier.
