"Service 4wd system" indicator light
JeepCares
Auburn Hills, MI
JL
2022 rubicon 9k miles 2.0 turbo engine and haven’t driven in 4wd at all yet. Service 4WD light coming on intermittently. I’ve also had some strange issues where jeep feels like it suddenly jumps into low gear. Pull off to side of the road and it felt like it went back into normal gear and then it drives fine. Dealer says I need new front actuator. Having it replaced next week so we’ll see. I’ll post updates. This “serv 4wd” issue seems to be a prevalent problem. @JeepCares should be pushing Jeep for a recall event!
Thanks for tagging us. If you need support with this at any upcoming dealership appointments, let us know.
Kate
Jeep Cares
AJRGobi
Aj
Pennsylvania
2018 Sahara 2022 GLS450 waiting on 2022 Rubicon
UPDATE: front axle actuator replaced and after a week, no warning light. Hoping it stays that way.
twelpo19
Tim
Flower Mound TX
2019 Jeep JLu Rubicon
Had the same thing happen to me on my 2019 Rubicon. Spent 1000’s with Jeep to fix with BCM…. It ruined out of state off road including Moab. Jeep dealer could not recreate at the dealership so guessing.
The real fix was simply a battery. The low voltage with all on made the charge to low so computer did not know what to do.
I now have a dual battery setup (Genesis) and problem solved. Good luck but don’t get taken like me.
Voodooridr
Idaho
2020 JLU WILLYS
Well the GF got the SVC 4WD light this morning on the way to work, 2WD, raining/wet roads. Going to check the fuses tonight, hopefully that's the issue. Been meaning to do that anyway after reading the forum
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
It isn't. That is a ghost story that the forum just loves.
It is more likely a connector is leaking water into the wiring harness.
Voodooridr
Idaho
2020 JLU WILLYS
She didn't get the alert coming home from work and everything seems to be working as it should
Is the 4wd indicator supposes to bling a few times before showing solid? These are issues I've never had to deal with on my LJ
mwilk012
Oklahoma
Service
Lights flash to get your attention, yes. Without pulling the DTC's to narrow it down, any amount of troubleshooting is likely a waste of time.
2mnycars
Canada
JLUR
