j_stew762
- Jake
- Jan 4, 2023
- Southern, IL
- 2020 JLURD
I purchased a stock '20 JLURD in Jan. No lift, 35's with 21k miles. In April I put on a 2.5 inch MC GC, Rocksport's, front drive shaft, and 37's. Took it to Axleboy in Missouri and they gave it a once over, helped me balance the tires (something DT couldn't figure out after two trips) and everything has been great. Now for the problems...
During the past 6 weeks or so, I've noticed the 2H light on the dash would flicker, with no rhythm, I have determined it would flicker as I went over bumps in the road (leading me to believe it's a bad wire, or ground?). Eventually the problem grew into the Service 4wd warning, which also disabled the sway bar disconnect feature. I can almost make the Service 4wd feature appear by reversing up my driveway (slight incline, 7-8 degree angle maybe, 4-5ft of rise over 35ft.). So I made the warning activate so I could plug in my splitter/vLinkerMC+ and tap into my Jscan. The following break down is what I have.
Anti Lock Brakes
U0403-00 implausible date received from transfer case
Drive Train Control
C1403-11 transfer case range position sensor - circuit short to ground
Driver Assistance System
C2227-00 abs disabled ecu
U0403-00 "same msg as above"
C2226-00 tcm disabled ecu
Park Assist
U0403-00 "same as above"
Sway Bar
I'm familiar with the fuses under the hood, and pushing them all down to make sure i have good contact, that's been done. I checked the abs wiring/speed sensors to each wheel and cant find a bad connector, or frayed wire that would cause the 2H light to flicker over bumps/when braking/when reversing up a hill, as previously described.
I'm familiar with after installing a lift, the linkage for the 4wd shifter may need to be adjusted.....may go down that rabbit hole today. I've also read that the transfer case switch may need to be replaced. I'm just not sure which it is based on the current symptoms of the Jeep, and it only having started after the lift was installed (case in point I bought in in Jan '23, stock with 35s, put 3-4k miles on it, no issues at all when lift was put on in Apr '23).
The 4wd still works, even when the service 4wd light is on, in both 4H and 4L. The only feature that's unavailable is the sway bar disconnect.
I have a trip to Colorado in a month, with a lot of trails on the list, and would like to get this fixed before I leave. Keep in mind, I trust dealerships like I trust the federal government....
Before I dive into this, what are some recommendations from the forum experts?
Anti Lock Brakes
Drive Train Control
Park Assist
Sway Bar
