Saddle adapter for bottle jack sizing
Opus
Midwest US
www.jlwranglerforums.com
Purchased a 3"-4" saddle adapter for my bottle jack. The adapter is meant to fit jacks 1.65" or less in diameter. Mine is 1" in diameter at the top which means there is a fair amount of play. Do I need to find a reducer of some kind to make sure they fit more securely together, or is this normal? Otherwise, I'm assuming I just need to make sure the jack piston is centered in the adapter when it makes contact with the Jeep.
Opus
Opus
Midwest US
I wondered about instability also, but so many of them are 1.65" or 1.5" and say "or smaller" so it seems like they allow for a smaller diameter jack piston.
txj2go
DFW
How do you plan on using the adapter? A lot of the pictures I found on the internet look like they are intended for using the adapter under the axle tube and wouldn't work under the frame or elsewhere. In my Jeep I carry 3 short pieces of 2x4 to use between the jack and whatever point under the Jeep where I want to operate. But yes I agree that no matter what point you are pushing up on you have to be very careful that it will be stable, and I wouldn't get under the vehicle using it unless it was a big emergency. I anticipate even needing to stack rocks under the jack to get enough height and would especially not want to get under the vehicle when doing that unless I could find something else nearby to function as a jack stand.
THAW
Foster
23 JL4DrRubicon
I use Safe Jack flat pads on the frame.
Jeep Wrangler JL Saddle adapter for bottle jack sizing SJFlatpad
txj2go
DFW
I am really missing the safe part there, and I have been known to do some sketchy stuff.
I've worked a good amount as a professional mechanic, whatever type of jack we used typically had a rubber pad at the point of contact so it would not damage the vehicle and so it would have friction and interlock so there wouldn't be any slip at that point. I mentioned that I carry blocks of wood which would do a similar thing. Is there something soft on top of that safe pad? It looks like it might be all metal.
Deleted member 107602
Guest
That was my thought. dead flat, smooth surface thats a hard no for me, it’s part of a jack, maybe for a floor jack in construction. Not an automotive jack. It’s a safety issue,
THAW
Foster
23 JL4DrRubicon
Good point. Adding friction between the surfaces is simple, though.
I use a generic, rubber, 4-inch furniture pad (up/lip-side down). It fits and works perfectly; the combination is much more secure than a 1.25-1.5 inch diameter bottle jack saddle on wood cribbing.
Jeep Wrangler JL Saddle adapter for bottle jack sizing 1000004196
Jeep Wrangler JL Saddle adapter for bottle jack sizing 1000004197
Guest
i would also ask how you intend to use it and what tonnage is your jack? Funny this would come up because I was just looking at the getting one. On a jeep the main reason I would use it is to steady and lower the axle after I have it jacked up or have it on a jack stand. Maybe to lift one corner to check articulation.
Opus
Opus
Midwest US
The jack is a 6-ton Torin Big Red bottle jack and the primary use would be for changing a tire. The saddle looks like this:
Jeep Wrangler JL Saddle adapter for bottle jack sizing 71BPn+Qb8UL._AC_SL1500_
I don't see a bottle jack lifting the frame high enough to get my tires off the ground. But I have 30" long shocks.
For my axle and frame jack saddles to fit my floor jacks and scissor jacks, I bought some leafspring axle pads.
Jeep Wrangler JL Saddle adapter for bottle jack sizing jack scissor
Terrymo
Terry
2023 JLURXR 3.6 ET
I bought a couple of 3.5 ton HMMWV scissor jacks back when they were plentiful for around $100. Now they have almost tripled in cost. I have these adapters from Agile Offroad for the HMMWV jack that allow you to lift from the axle or the frame rail. I keep one of the jacks at the rear of my Tuffy Security box and one in the garage.
Jeep Wrangler JL Saddle adapter for bottle jack sizing IMG_2720
Jeep Wrangler JL Saddle adapter for bottle jack sizing IMG_0460
Jeep Wrangler JL Saddle adapter for bottle jack sizing IMG_0459
THAW
Foster
23 JL4DrRubicon
Agreed. In an emergency (in which for some reason I couldn't lift from the axle), I'd have to strap the axle to the frame or use a strap to compress the shock. Or alternate my 2 bottle jacks on the frame, stacking them with extensions/cribbing.
I mainly use the frame pads for leveling the vehicle at camp. In the field, I can also use my second bottle jack with a pad on the frame as makeshift jack stand.
My two 4-ton jacks, extensions, and adapters all fit in the factory jack compartment (no problems storing the hydraulic jacks on their side, so far).
