Running wiring across engine bay?
IQ_imbalance
Bob
Maryland
2022 JLU Rubicon 3.0d
Sticking this here as it applies to a few different situations (mods feel free to move!)...
I did some searching and wasn't able to find much on running wiring -across- the engine bay. I'm wondering what people's experiences and opinions are. As I see it you can run something under the trim between the cowls (where the windshield motor is), you can just ziptie to the firewall, or (yet to be verified!) you can try to run with the factory wiring...it looks like there might be a plastic conduit at the top of the firewall on the JLs.
Update: there definitely is a wiring conduit, and I think this is the way i'm going to go....
JABCAT
Prosper, TX
'20 GC High Altitude 4x4, '22 JLU on order
College Professor
Whenever I run wiring I always try to run it along the factory wiring. I haven't done it yet in my JLU (because it isn't here) but have done it in my JKU, GC, Corvette, etc.
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
Helpful video. Thanks for posting. I didn't know about that raceway running along the top of the firewall. I have some wiring running/ziptied just above that. I might have to go clean that up.
mikej
SF Bay, California
2018 JLUR, 2023 Rivian R1T
Wow, I didn’t know about that conduit. That will definitely clean up some of my wiring. Thanks for posting that video!
sigsegv
Adam
Seattle, WA
Wow, I had no idea. I had zip-tied wires right next to the conduit without realizing there were wires right behind it. Thanks!
IQ_imbalance
Bob
Maryland
UPDATE: installed the diode dynamics harness (OEM auxillary switch dual-output 2-pin wiring harness) and ran it through the conduit. There were a total of 6 10mm nuts to remove (including for the coolant reservoir bracket), then it was just a matter of popping the connections with a small screwdriver like in the video. it's a tight squeeze behind the battery but you can make it work without removing it.
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
This wiring runway was actually mentioned in a couple of forum posts back in 2018.
When I first read about it, I went right out to my JL and took a looksee.
Yes, tight working area where the PDC is, but it's doable.
OldBlue
Doug
Chatham Twp, OH
See my Signature
Aerospace Forgings Test Lab
I ran the wiring for my cowl lights through the conduit. Pics HERE.
Jerpy
2021 JLU Rubicon
Just now seeing this and yes, this is how I've run the wiring for some of my accessories – really appreciate the video (which would have been helpful when I was doing my mods)! 😆
