Rubicon locker switch
Mark D
Beaumont Ca
2021 Gladiator
Yeah that’s a SOLID pass just for two connectors lol here’s the part numbers for everything you’ll need.
When wiring of the factory lockers is it simply positive and negative and either on or off?
Jeep’n Jay
Jay
Salt Lake City
2018 JLU Sport
I recommend if you are wiring lockers you run the switch to through a relay to prevent frying it.
zrickety
Technician
I run mine with the low amp Auxiliary switches, 3 and 4 without issues.
Gregj
Aux switches still go to specific relays IIRC.
Gregj
Greg
West Texas
They are on relays, I don’t think it’s that big a deal as the amp draw for that actuator is not very high. Any good quality switch would have no problem carrying the load.
Gregj
zrickety
Technician
Gregj
I'm having trouble finding a circuit diagram, but it looks like the lockers are on a 15 amp fuse...so a standalone switch would need to carry that current.
Gregj
Greg
West Texas
15 amps is the max current before the fuse blows, the actual running amps is much less. The wire to the locker is a 0.75 mm or a little less than 18 gauge (0.83 mm) which when used in a continuous duty is rated at about 3 amps. The size of the wire says to me the load on it is pretty small.
Gregj
zrickety
Technician
Gregj
This is good info. I don't want to drag out the thread, but I'm seeing 18 gauge rated as high as 15 amps. Not saying that's what the actuator needs, but I would choose carefully if wiring up my own switch.
CaJLMetalHead
CAJLMetalHead
Jeep Wrangler Sport Unlimited
Gregj
Gregj is correct.. I measured the continuous current consumption of the lockers and is around 3 amps.. so a switch could easily handle that load.. no need for a relay.. however !!!! do not forget to add a fuse to the circuit ( 15 amps should be ok )
Let me know if you want me to be more specific on how to properly wire the lockers..
Jeep’n Jay
Jay
Salt Lake City
2018 JLU Sport
Thanks for the info. I have the Voswitch 6 switch panel with built in relays and fuses I will use.
Awesome. I use the VO Switch also for mine! Plug and play for any future upgrades.
NyRey87
Nyles
Reno, NV
2021 JLURD
I just got a set of 392 Rubicon takeoff axles and he threw in the factory locker switch. I already have the factory wiring harness for the front and rear. Can the factory switch be used? I have a Tazer mini and the owner of the axles said I should just be able to flash it with the tazer to get the factory switch to work. Any help would be appreciated. Especially if I can save 2-300 bucks on the Voswitch or the Last Switch options. Thanks!
19 JLUR Bright Whit3
Baba Yaga
NJ
www.youtube.com
2019 Stretched 2 door Rubi (LOL), 2004 TJR
Retired LEO
I could be wrong, but what I am getting is that the OP abandoned wiring to an OEM switch as it would be more costly. I have been researching the opposite and trying to get my lockers off the OEM switch onto separate switches. I like controlling the lockers as needed, not just all or rear only. (I have a hard time with getting it in rear only anyways)
