Rock Krawler vs. Clayton
TheJanitor6203
TheJanitor6203
Evan
Austin, TX
2020 JLUR, 2.0 turbo, auto
That’s the Mopar steel bumper with the end caps off.
Interesting. Mine looks like the one on the other Jeep in the picture. Is it possible to convert mine to that or is that a different bumper than mine?
Country JLU
2020 JLUR
Absolutely. It’s a direct bolt on factory bumper. I have it on mine. Great looking bumper.
rustyshakelford
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
Final question for now: does anyone know how wide the factory wheels are? Are they wide enough to run 12.5" wide tires? I don't really want to replace them if I don't need to. Maybe some day I'll add a set with bead locks but don't see a reason to change them until then.
places like discount tire won’t install a 12.5 on the stock wheels. I think they are 7.5” wide. They however mount up fine and I haven’t noted any poor tire wear. I would suggest some synergy or spidertrax spacers. There’s a member selling some in the market place or order them direct. It’ll give you plenty of clearance from control arms or sway bar end links
brett
scottiea11
Raymond
Jeep Wrangler Rubicon Jl 4DR 2018
I’m going to go with the cheaper Fox 2.0s when the time comes. I’m probably several months out at a minimum from installing a lift. Just got the Jeep Friday and will focus on a few smaller items in the interim (bumpers and winch).
Right on! Enjoy it brother, it’ll eventually snowball into stuff you’d probably said you wouldn’t buy!
scottiea11
Raymond
You gotta use the Torx bit to remove the end caps. There should be a mopar tool kit your Jeep came with. I did it with mine.
OversandJL
Massachusetts
2018 JLUR, 2017 JKU Sahara, 2014 JKU Sport S, 2007 JKU Sport, 1997 TJ,
Yes 2.5" is available in the Overland kit as well! I can leave you a link. We always at least recommend changing out the front driveshaft, but when it becomes really necessary is when you start to get over 3" of lift, and also if you're going to be taking it wheeling a lot. If you're doing the 2.5" kit, and only wheeling once in a while, you might be able to get away with holding off for a little bit before upgrading.
https://www.claytonoffroad.com/product/jeep-wrangler-25-overland-lift-kit-2018-jl
Here's my Clayton 2.5 Overland Plus on 38s and 37s! Running Fox 2.0 Shocks. Still haven't needed to upgrade the front driveshaft.
Jeep Wrangler JL Rock Krawler vs. Clayton IMG_20200531_210521_060
Jeep Wrangler JL Rock Krawler vs. Clayton 15974287352559215265707847085306
Jeep Wrangler JL Rock Krawler vs. Clayton IMG_20200621_082520_924
Jeep Wrangler JL Rock Krawler vs. Clayton IMG_20200623_100249_185
TheJanitor6203
TheJanitor6203
Evan
Austin, TX
Very clean! Can’t wait to get mine on. Current plan is to go with the 3.5” Overland Plus (With the RK No Limit sway links) on 37s when the time comes.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Great! Thanks! That’ll shave a good $700 or $800 off if I don’t need wheels or spacers.
I ran 315/70-17 BFG KO2's, which are a smaller 35", on the factory wheels without spacers for about 10k miles. Zero issues.
ChattVol
Tennessee
JLU 4 door
Nice...are you not disconnected in the front in the last pic where your lifting a tire?
OversandJL
Massachusetts
Agswin
College Station TX
Just a heads up, when you go to claytonoffroad.com and put in a "your vehicle" which is 2020 Jeep Wrangler and hit the search button, the 2.5 Overland is not displayed. When you click on the box to the left for "JL" it still doesn't display the 2.5 Overland. It has just 4 listed which are as follows
2.5 Premium
3.5 Premium
3.5 Overland
2.5 Entry Level
This may be why the poster didn't think you offered a 2.5 overland
TheJanitor6203
TheJanitor6203
Evan
Austin, TX
2.5 Premium
3.5 Premium
3.5 Overland
2.5 Entry Level
I did end up finding it after Clayton responded but I’m guessing you’re correct in why I didn’t see it the first go around.
Clayton Off Road
Summit Sponsor (Level 3)
Hamden, Ct
2.5 Premium
3.5 Premium
3.5 Overland
2.5 Entry Level
Thank you we will address this!
Clayton Off Road
Hamden, Ct
