ROAM MK3 Rock Rail Installation
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
This installation is fairly easy, but figure some may benefit from a DIY.
Torque specs:
M6 -> 9 Nm / 7 ft-lbs
M6 (trilobial) -> 6 Nm / 4.4 ft-lbs
M8 -> 22 Nm / 16 ft-lbs
M10 -> 44 Nm / 32 ft-lbs
M12 -> 77 Nm / 57 ft-lbs
3/8" -> 44 Nm / 32 ft-lbs
The Brackets are all marked with small holes to signify their position, and arrows to signify their orientation. The bracket with one hole goes to the very front, and the bracket with 4 holes goes to the rear. I have roughly positioned the 4 brackets where they will be mounted as well as the flag nuts to secure brackets #1 & #3.
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_121745_resized
In the hardware kit there will be some longer bolts, and some shorter bolts. The 6(per side) longer bolts go into the mounts that attach to the side of the frame(Bracket #1, and #3.) Washers are to be installed on every bolt. The shorter bolts secure the steps to the mounts. The smaller 10mm head nuts are for the logo plate on the backside of the rails.
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_122140_resized
First thing you will want to do is attach the logo backing plate to the rails as it is a little difficult to get installed once they are mounted on the Jeep. The plate needs to slide into the top of the steps first and then over the mounting studs. Use the 4 10mm head nuts to secure them in place. We will be covering our plates in Red Vinyl to accentuate the logo, but for this installation we kept the plate out.
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_122952_resized
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_123044_resized
This next step is easier with a second set of hands. Grab bracket #1, and take the long 4 hole flag nut and fish it through the frame so all the holes roughly line up. Using the longer bolts/washers loosely secure bracket #1 to the flag nut.
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_123421_resized
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_123428_resized
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_123405_resized
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_123653_resized
For Bracket #2, you just need to remove the two body mount nuts then slide the bracket over the large body mount washer and onto the studs. Secure the bracket with the 2 factory nuts.
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_123856_resized
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_124015_resized
For bracket #3(Just like #1) a second set of hands makes it easier to hold the flag nut in place.
Slide the flag nut in place keeping note of the orientation arrow. Once in place loosely mount the bracket with 3 longer bolts & washers.
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_124128_resized
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_124200_resized
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_124338_resized
Bracket #4 is just like Bracket #2. Remove the rear body mount nuts, slide the bracket over the larger body mount washer and secure it to the studs with the factory hardware.
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_124412_resized
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_124635_resized
Once all the brackets are installed I found it easiest to tighten the #2 & #4 as they are for the most part in a "fixed" position. Once secured mount the steps on top of the brackets and used all the shorter bolts/washers to loosely secure the brackets to the steps. I found it easiest to start with the 4 bolts on brackets number 2 & 4, then slide mounts 1 & 3 up until I was able to get the remaining bolts threaded. Once all the bolts are threaded align the rail height front to back and then tightened the 6 bolts securing brackets #1 & 3 to the frame.
Once all the brackets are tightened use a piece of cardboard between the body and the rails in order to keep the same body gap front & rear. I slowly tightened the bolts securing the rails starting from the center two brackets and working my way out. Keep an eye out for the gap as it may change as you are tightening the bolts.
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_130540_resized
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_130533_resized
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_130201~2_resized
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 20191012_130437_resized
Repeat on the other side, and admire your work!
maxjlu
fred
california
jeep jl
Thanks for sharing! Very useful! How did you get the special LOGO version?
Tpham
Tom
ohio
2018 jeep wrangler sport s
if you dont have help for the flag nuts it makes it easier to use one bolt to secure the flag nut and bolt one one in somewhat snug and rotate the bracket then proceed to install the rest. i speak from experience lol..
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
After reading the write-up, I’d like to get one myself.
Where can I order this?
TTEChris
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
I've helped ROAM test a lot of their prototype parts. They surprised me with a set with our company logo as a thank you. :beer:
@ROAM offroad makes the steps. You can PM them on the forum, but it is better to call or email them.
roamoffroad.com
shekmark
Manasquan, NJ
Yes
Did you use blue locktite on the bolts? Are there torque recommendations in instructions. Thanks.
CaddyshackGopher
North Dakota
2019 Sting Gray JLUR
Anthony sends an e-mail when they ship including the following:
Torque specs:
TTEChris
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
All the bolts/nuts are serrated which act like a lock washer, but in final assembly I use blue loctite.
Clay
Greensboro, NC
2018 JLUR 1981 CJ7
Great write up and it helped me with the installation, I didn’t get an email and I am wondering why they feel the need to not include instructions?
also what are the extra threaded holes in some of the brackets for?
TTEChris
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
Great write up and it helped me with the installation, I didn’t get an email and I am wondering why they feel the need to include instructions?
Thanks.
The extra holes on the rails are for different mounting brackets(body vs frame mount)
shekmark
Manasquan, NJ
Yes
Installed mine last weekend. Frame mount. I got no instructions at all. Just two very heavy boxes. If not for forum advice I don't think I could have figures it out. First side took me three times longer than the second side. Learning curve. I used blue locktite on all but to be honest I nixed the torque wrench. I will probably never rock crawl so not sure it matters. I love these. Made the ROAM name red to match my Rubi highlights.
Jeep Wrangler JL ROAM MK3 Rock Rail Installation B7B85A50-58AB-428B-99A5-D46A9D8C53C7
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 414DCC40-65A8-462F-9C21-7A89FD059D97
Jeep Wrangler JL ROAM MK3 Rock Rail Installation 96185AFB-E6A9-4108-920E-6223D96DC126
