Recommended KO2 Tire Pressure
jeme
TBD
I put some KO2's on Willy's wheels on my Sahara. Was wondering if anyone has a pic of the recommended tire pressure from a Rubicon.
The tires are 285/70/17 KO2's. Discount tire filled them to like 48psi, but I think that is way to high - anyone have a pic of the tire badge from a vehicle that has KO2's from the factory?
I checked in the manual and it is not there unless I missed it. Thanks in advance!
sciotola88
Stan
Boerne
2022 Willys Ecodiesel and 2020 JTR
Underwriter
i have 37" ko2 and i find that 30psi works best for me. I cant speak to what works best in the smaller size but i can tell you 48 is wayyyy too high.
rcadden
Ricky
Asheville, NC
Marketing
I believe the recommended is 37 psi, but I keep mine a little lower at 35 psi cold.
You should run the chalk test to find the best PSI for your setup.
Search YouTube for "tire pressure chalk test" - super easy to do.
jeme
jeme
TBD
Excellent - thanks so much!
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Confirmed, our rubi door sticker is 37 factory.
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
I ran my 35” K02 around 30-34PSI.
My 37s have much less wobble on the round at 26psi cold.
kah.mun.rah
Merenkahre Jr.
Duat
35 cold is where my chalk test came in
Murphydog
Seattle
2020 X3M, 2023 JLUR XR
40+ is going to be too high, as others have said the door jamb sticker is 37 - though I would say experiment with it and find what drives best for you. I settled at 35 cold for mine. I don't think the TPMS will trigger unless you are below 30
Jim1964
Jim
Traveling the US of A
2022 JLUR
37 is what the Rubicon spec is and the factory knows what they’re doing. I run that whenever I’m not aired down. There’s more wear on the edges than the tread center even so, although that’s probably all the twisty CO roads. I corner somewhat quickly.
CarbonSteel
Rim width plays a major factor in contact area
Agree; but I am running 17x8.5 wheels and can in no way come close to full contact at 35PSI. I am not even at full contact at 30PSI, but I will not go lower than that. Others running K02's have reported similar with similar width wheels.
Then again, he has a propensity to and is very adept at finding unicorns...
