Recommendation on rodent spray
Captain Tuttle
PA
2023 Toyota 4Runner Limited, 2023 Jeep Willys
I use this ^^^^, but I enhance it with this https://www.amazon.com/Natures-Truth-Aromatherapy-Essential-Peppermint/dp/B00X47GZOG?th=1 (also available at our local CVS)
I add about 8 additional drops and give it a good shake before spraying. My rodent problem went away.
Bonus: my driveway area smells 'minty' ;)
So, I get the idea of using minty spray. But, where exactly on the Jeep are you spraying this? The engine bay from the top? Engine bay from the bottom? Undercoat the whole Jeep?
sherpaJL
Keystone State
2019 JLUR Mojito! ~ 2022 JLUR Hydro Blue
Ruby Mike
Southern California
2020 jeep wrangler diesel
I read that WD40 works wonders for mice, rats and squirrels. I kept having a mouse build a nest between the battery and fuse box. I would remove it and the nest would return in less than 4 days. I sprayed the wires, firewall and all over the frame. So far no mouse has returned and it has been 2 weeks.
saturnfire
TRX, ARMADA, SEQUOIA
I had them building nests in my engine compartment. I was skeptical, but a few dryer sheets have kept them away.
I would try this and peppermint oil first.
pure peppermint oil. I would also get bait traps. around your property.
For squirrels....not sure if you can still buy this. I have eliminated most of the Squirrels that were on my property:
A18 Squirrels Trapping Kit with Tree Mount,
WannFly
WannFly
Priyo
Atlanta
2021 Rubicon 4Xe, 2026 MOAB
Cyber security
Thanks everyone, I will check out some of the recommendations.
So far the bastids seem to like my Jeep better than the RAM ....
Passenger side (ignore the hanging wires, a lot going on with wiring right now)
Jeep Wrangler JL Recommendation on rodent spray 1703893732618
and then they checkout the battery terminal
Jeep Wrangler JL Recommendation on rodent spray 1703893780652
WannFly
WannFly
Priyo
Atlanta
Cyber security
If you keep it in a garage, get a cat and leave the door to the garage open, keep litter box in the garage. IF a rodent tries to get in, it’ll get digested. But they will smell the threat and stay away.
Garage is where my sweetheart's Audi stays. Jeep in the garage - iant gonna happen. + I its a 4Xe, so might blow up anytime now
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
Opus
Midwest US
www.jlwranglerforums.com
Probably too slippery for them to get a good purchase... :)
richk225
Rich
New Jersey
2021 392Rubicon XR 2017 Jeep Grand Cherokee
retired due to broken back
That's because he keeps sliding down the wire
RCW1024
Ray
Hickory Withe, TN
2018 Tacoma Limited
all along the lower half of the firewall inside the engine compartment, along the fenders inside the engine compartment, behind battery and surrounding area, around perimeter of hood insulation panel, and fender wells where they meet the frame, front & rear.
Instead of that, my wife made small burlap pillows with absorbent foam inside and I add a few drops of pure peppermint oil to the pad. Mice and squirrels hate it. Been using this on my vehicles for about ten years and so far, it works without mess and lasts about 45-60 days.
TrentYoung
Trent
Phoenix
2024 Jeep Wrangler Rubicon X 4Xe
I am need of some kind of spray to keep rodents away from my cars. Just noticed some arsehole have chewed the insulation under the hood. Before they chew on any of the harnesses I need a remedy. Can anyone recommend a tried and tested one? there are dozens on amazon, just not sure which works best.
I believe the culprits are squirrel but could be mice as well.
Glue traps.... 100% glue traps. May sound inhuman but so is the cost to have your wiring redone. If you use a glue trap then you know you got the culprit. My neighbor had wiring eaten to the tune of $1,500 in one night. Spent the money and had it replaced and tied all kinds of varmint sprays and sonic deterrents.... two days later... back to the shop with eaten wires again. Again, another $1,500. Week later he got it back and laid the glue traps. Got two squirrels and a large rat. He put them in a bucket of water to end their lives. He still places the glue traps out but hasn't had an issue since. Moral of the story... do unto them before the do unto you.
RCW1024
Ray
Hickory Withe, TN
2018 Tacoma Limited
Hard Rock Jeep
Richard
Nashville
2016 JKUR HR, 2022 JLUR 2.0, 2022 JLUR Diesel
My New Year’s resolution one year was to shoot every squirrel I saw in my yard. I killed 19 over a few months and realized that you can never get rid of them. They kept coming back like I was in some video game loop. And of the 19, 18 were gone the next day.
I was feeding some larger predator.
I am pretty sure that if I were to kill those predators, they would have been eaten by bigger ones and ultimately I would have been eaten.
I just now ordered some peppermint oil. Not sure what will come of it; might get mice making candy canes decorating the wires under the hood.
richk225
Rich
New Jersey
This is one of the sponsors from Hot Rod Garage and they say they work.I have a plug in ultrasonic device that I have in my shed and have not had 1 mouse since
https://mouseblocker.com/
