Rear inner axle seal
Dieselruby
Ryan
Wausau, WI
2020 JLUR
Replaced my axles with chromoly. I’m doing so initially ordered the wrong axle (non rubi axle shaft not rubi). Resulted in needing to remove the axles and replace with the correct size. The issue is that when removing the driver side I found diff oil in the tube but not in the passenger side. I cannot seem to locate a part or part number for the inner seal which I believe I damaged in swapping the axles. Dealer has told me there aren’t any that the fluid should run out to the wheel bearing. I am pretty sure there is a seal on the inside (where the shaft enters the diff/pumpkin. Can anyone confirm there is one there and further anyone have a part number for such? Or is the dealer actually right and the newer JLs don’t have one. Axle is a 2020 rubi rear. Appreciate the help.
jlandry287
2022 JLUR Diesel
I swapped my rear recently and there was a small amount of oil in the passenger side but none in the driver.
Pretty sure there is a seal, as you have to get it lined up with “something” near the diff in order to fully push it in.
Dieselruby
Dieselruby
Ryan
Wausau, WI
2020 JLUR
That was my recollection can’t find a listing for part on online schematics and neither can the dealer
19 JLUR Bright Whit3
Baba Yaga
NJ
www.youtube.com
2019 Stretched 2 door Rubi (LOL), 2004 TJR
Retired LEO
I am about half the time wrong, (LOL) but my recollection is your axle seal is at the end of the tube by your wheels and there is a bearing (a possible seal too) at the pumpkin side. When I had a leak, I replaced the seal at the end of the axle. My $.02 ?‍♂
Dieselruby
Dieselruby
Ryan
Wausau, WI
2020 JLUR
There definitely is an outer axle seal toward the wheel bearing/hub. Think there is an inner seal too that keeps the fluid in the pumpkin by all the bearings and gears in the diff. Guess I’ll have to pop the cover and check it out. I’ll post what I find and if I ever happen to find a part number.
Baba Yaga
NJ
www.youtube.com
Retired LEO
Just a thought. Your fill level is just a tad bit higher than the bottom of your rear axle tube.
I'll be following for your findings. ?
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
There is no inner axle seal in the rear axle. The gear oil runs down the tube to lubricate the outer bearings. If you lift up one side of the axle it drains to the other side. If you drain the axle it won't have much in the tubes.
Dieselruby
Dieselruby
Ryan
Wausau, WI
2020 JLUR
And the plot thickens…. Later today I’ll drain and pop the cover see what we find….
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
And this
