Front axle shaft seal replacement
Cbacon
Corey
Spring Hill, KS
2019 Rubicon
Any good videos or threads on replacing front axle shaft seals?
I will be replacing right side front seal. Can't seem to find any JL videos, all older one without the FAD.
Looks like seal is by the FAD. Have two piece RCV axles.
Also doing the American Iron ball joint deletes. Plenty of videos for that.
Thanks
Jeep Wrangler JL Front axle shaft seal replacement PXL_20240321_142509515
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
The only real difference with the FAD is where the seal sits. It's outside of the FAD mechanism instead of being in the differential housing. The process to drive it out and the new one back in is pretty much the same.
