How does axle shaft seal (inner axle seal) work?
plex
Cincinnati, OH
Weekend keyboard mechanic and beer drinker
I am curious because yesterday I pulled out my axle shaft while changing the ball joints.
How come when I pull out the axle shaft, there is no oil leaking out from the axle tube? Is there a seal in the differential preventing gear oil to flow out?
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
Yes, right at the end of the tube into the housing. I reccomed putting a litte grease or oil around the end of the shaft when sliding it back in so the splines slide easier over the seals and dont catch on it
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
Also oil will leak, when i pull shafts i do one side at a time if i can and tilt the axle the other way so oil doesnt come out the tube
plex
plex
Cincinnati, OH
Sounds like it is better doing this while changing gear oil.
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
It doesnt hurt to do at all that way. Specially if the inside of your tubes dirty or muddy and the end of the shaft grabs some of it before it makes it all the way down there, but usually not a problem. I tend to just tilt it a tiny bit like i said and run my shop vac hose down the tube to get any loose dirt or whatever, just as a precaution
