Questions for Rock Krawler Front LCA
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
Really want to go for the Rock Krawler arms.. but
Does anyone know if the Rock Krawler front LCAs have this bend inward for better tire clearance at full steering lock to lock? I know they seem to have a bend upwards for clearance against rocks, but they appear to not bend inward. Anyone can confirm?
This is important for me because my tire is basically a hair from my stock LCA at full lock.
EDIT:
Thanks to word302, I found the answer to this already.
word302
Oregon
JLU
EDIT:
I found the answer to this already, thanks.
I'll answer again here for anyone that doesn't see the other thread. RK LCAs do not bend inward, they bend upward for ground clearance. If you check out their install instruction on their website they give recommended minimum backspacing for each tire size based on model and lift height.
Roky
Roky
@Arterius2
Hey Jerry,
If you go with rk xfactor lcas, a couple things to keep in mind. The grease fittings are hard to get to, and the jam nut might hit the bracket at full flex, depending on length of your shocks. To alleviate this problem rk recommends that you notch out your lca bracket like this....
I used a metal hole saw to cut mine...
Of course if you don’t have a problem with the jam nut hitting, and you don’t want to notch your bracket, you can use a 90 degree grease fitting, it’s still tight but you can get a grease gun on them. Or you can take them loose to grease them.... :) ... imho these are some of the best arms on the market.
ChattVol
Tennessee
JLU 4 door
@Arterius2
Hey Jerry,
That is a sizeable hack into the mount that has to weaken it. For my RK arms, I cut out about half of what they recommend and it allows full droop. The problem is I now cant get the hard to find 000 grease into the fitting without dropping the arms. I tried 90 degree fittings and cant seem to get grease into them. All things considered, I would buy Metalcloak if I could do it again....these arms are a pain and I dont like hacking the mounts.
word302
Oregon
JLU
It doesn't weaken the mount at all. It's just extra metal you're trimming away. Completely non-structural.
MarkY3130
Denver
2019 JLUR
On my JK I had the greasable monster joints and found them difficult to access on some of the arms. One of my top reasons for going Metalcloak in my JL is so that I didn’t have to grease them.
I still have to grease my Steersmarts stuff so it’s not that scared of greasing.
word302
Oregon
JLU
I mean, you're heading them maybe 3 or 4 times a year. I added 45 degree zeros for the hard to reach ones. It's about a 20 minute job once you get it down.
word302
Oregon
JLU
If you wheel hard you're going to end up replacing those Metalcloak bushings more often than you think. Not a huge deal but still not "worry/maintenance-free" like everyone says.
MarkY3130
Denver
2019 JLUR
After 8 years of greasing them on the JK I know the greasing drill. Still though, every time I was doing it, I was telling myself how much I looked forward to my next Jeep without them
word302
Oregon
JLU
Meh. I'm under there re-torquing things often enough that it's just not a big deal for the strength/durability you get from them.
MarkY3130
Denver
2019 JLUR
For sure. Though I had to replace them on the TF joints after 4 years as well.
MarkY3130
Denver
2019 JLUR
Im just glad we’re both happy with our choice!
