Question about aux battery...
apriljeeps
apriljeeps
April
United States
2019 jeep wrangler rubicon 2013 jeep wrangler
Self
Fuse F42 should be intact.
The N3 fuse on the Z Case Fuse Array is the immediate concern. If you blew it (likely), the new AUX (ESS) battery no longer has an electrical connection to the main battery and alternator; once it's drained the Jeep will stop running and/or fail to start.
To prevent this issue until replacement of a faulty Z Case Fuse Array, it's possible to temporarily connect the N3 wire terminal to the unused N4 post (same fuse rating).
(N3: third from right; N4: no nut)
Ohh wow. Ok. This is very helpful thank you!
apriljeeps
apriljeeps
April
United States
Self
All good advice noted above.
With all of today’s high tech systems and extensive electronics, I replace all my batteries every 3 years on all my vehicles. This has eliminated a ton of heartache and odd issues. Most of these systems freak out when there is a voltage anomaly. So I no long try to get the maximum life out of a car battery. Best of luck!
Thank you. Excellent advice. Now I can also keep track of replacements I do moving forward.
apriljeeps
apriljeeps
April
United States
Self
Do yourself a favor and just remove the AUX battery. Pull fuse 42. Push the auto start stop button Everytime you start jeep.
I don't need this battery? It would make life easier for sure. Thank you.
melendez69
Marc
Waxhaw NC
...huh?
Make sure you wrap up the negative cable with a few layers of electrical tape…. Keep it up & outta the way from contacting anything.
apriljeeps
apriljeeps
April
United States
Self
Ok. Duly noted. I'll make sure I keep it secure. Thank you!!
apriljeeps
apriljeeps
April
United States
Self
Nope. Been running without for two years.
Interesting. I wonder why people say it could ruin other components. I think you're onto something here. Maybe I should just take it out!!!
melendez69
Marc
Waxhaw NC
...huh?
Many, many owners bypass and remove the auxiliary battery. I don't know how much truth there is to this method affecting other components since it exists for the auto stop/start system. I haven't seen that mentioned here.
Since I have the Genesis dual battery kit, I don't speak from experience. If that were the case, I doubt most here would (strongly) recommend removing the aux battery.
apriljeeps
apriljeeps
April
United States
Self
Take a look here, it's in the power distribution center (on the right, by the passenger-side firewall, where all your fuses are located)... but since you mentioned learning.... maybe you should take this to the dealer if it has to be replaced.
Thank you foe your help.
Old Dogger
Cave Creek Arizona
Yep, me too.............
