Press Clutch and Push Button to Start
jdhend1
Largo, Fl
2024 Rubicon X JL 2 door
SQA Manager
Hi there.
I have a brand new 2024 Jeep Wrangler Rubicon and when I turn off the vehicle, lock the doors and walk away, the “press clutch and push button to start” light illuminates in the dash and does not go out. My key fab is inside my house with plenty of distance away from the vehicle. It has already completely drained my battery and required a jump start.
The dealership does not know how to fix the problem. Can you help?
jdhend1
Largo, Fl
SQA Manager
I also have a 2024 Ruby X - automatic transmission. Same thing is happening to me. Cluster light stays on. Dealership is baffled. I get, "weird, strange, wow- havent seen this before", as my answers. Now I'm driving a rental until they get this resolved. Needless to say, this sucks. I traded in my MB AMG convertible for this Jeep. Not happy.
OrneryBear
Charles
Central OH
23 Sarge JLUR 6spd
As already established this isn't normal. Our 23 manual goes dark until the fob enters the vehicle, but it will time out if the fob is left in the jeep for a certain amount of time as well.
jdhend1
Largo, Fl
SQA Manager
I hope I'm wrong, but I am having a grim feeling that this is just the beginning w/this issue. I think its the new 12.4 inch display, but who knows. Next up is a national recall. Not good.
bburgess214
Orlando Florida
Sounds like we are in the same unfortunate boat. Sorry to hear this for you. Thanks for keeping me posted with what Jeep uncovers for you. I’ll do the same.
bburgess214
Orlando Florida
Which battery, and were they able to replicate the problem? Check your fuses...push 'em all in... it's a running gag around these parts, but some have found them loose. Most likely not the issue, but it doesn't hurt.
So they expect you to keep draining batteries? I haven't heard of this being a thing & I'm sorry I'm not of much help, but maybe try another dealer... a competent one.
Thank you. I checked the fuses and all were set in place. Unfortunately, it didn’t do the trick. And yes, the dealership said to keep driving it with the hope that the issue would resolve on its own. Yes, seriously.
Bob Burd
Bob
San Jose, CA
www.snwburd.com
Not a solution, but a band-aid, but I'd suggest putting it on a trickle charger while at home. Will save your batteries from repeated depletion, at least, and keep it useable until solution is found.
Beachcomber72
2022 JLU High Tide
This is not the first time this issue has been discussed, I’ve actually seen 5 threads on this particular topic over the last 2 years.
Gregj
Greg
West Texas
In the pictures you posted the drivers door is obviously open but does that icon disappear when the door is closed?
Gregj
melendez69
Marc
Waxhaw NC
2018 3.6 JLR / 2013 991 911 / 2013 E92 M3
...huh?
Gregj
Greg
West Texas
So I went and did some fiddling with mine and I wonder if the brake pedal position switch is out of adjustment? It doesn’t take much movement of the pedal to wake up the dash, this would effect both stick and automatic Jeeps.
Gregj
melendez69
Marc
Waxhaw NC
...huh?
bburgess214
Orlando Florida
Gregj
Good question. Yes, it appears when the doors are closed and the key fab is not close to the vehicle.
