Power Mirrors and Lock Not Working
BSearle
Brent
Sierra Vista, Az
2018 UNLIMITED sport
Alf you are absolutely correct. I disconnected and inspected the driver side harness and sure enough it repeatedly kept bending back one of the pins. Finally got it sorted out and having working mirrors and door features.
clayps
London, Ontario Canada
2010 Jeep Wrangler Sport
I know we're talking about FCA here, but they really should have considered engineering a connection that is meant to be disconnected over and over again. They likely used a similar connection to something in a normal car that is never disconnected over the life of the vehicle and therefore won't experience bent pins.
Trefflek
Rosemount, Minnesota
2018 jl Sahara wrangler, 2005 Chevy Avalanche 2500 with plow, 2006 subaru impreza, 2013 camry
I have the same problem and I looked at the pins on mine and can't find anything wrong with them. I pulled the fuse, reset and nothing. tomorrow it goes into the shop to see what they can find. I am curious to see what my dealer comes up with. My remote start isn't working either.
JeepCares
Auburn Hills, MI
JL
Hi Trefflek,
Sorry to hear of the concern you are experiencing with your Wrangler. Please keep us updated on your dealer visit. If our team can be of any additional assistance, we would be more than happy to help. We're just a PM away.
Jeep Social Care Specialist
Trefflek
Hi Trefflek,
Well, i should be embarrassed in myself. I checked the driver's door pins on the quick disconnect but did not check my passenger's door. In the end, it was a bent passenger door pin that was causing my problems. It wasn't a wasted trip though, Jeff Belzer's fixed my pins, replaced my steering damper under a recall, took care of my free oil change and did a front end alignment all with-in 3 hours. Next time i will pay closer attention to the wise advice of this forum.
JeepCares
Auburn Hills, MI
JL
Hi Trefflek,
Thank you for following up with us to share this update. I'm thrilled to hear that you were able to take advantage of your trip to the dealer and that you received the level of care we expect for our customers. If you are ever in need of any additional assistance with your Wrangler, we're always happy to assist.
chris4prez
Tampa
'20 JLUR
I've had similar issue with bent pins in the door connector causing the passenger mirror from being able to work. And this was after my first time taking door on and off. It's crazy that they used such tiny pins susceptible to bending. This connector should have been made much sturdier.
davejkenny
Melbourne, AUS
JLU
I was looking for this to fix my issue as well. Are the bent pins usually in the door side or the car body side. I will have to have a look when i get home from work.
thanks
chris4prez
Tampa
'20 JLUR
thanks
Pins are on the car body side connector not the connecter coming from the door.
mathum
matt
south carolina
2019 Wrangler MOAB
I had the same problem today. I had the doors off for a few days (first time), stored them safely. When I put them on, neither side mirror was working, although the door locks and power start did work. I also got the warning that the blind spot alert was temporarily disabled. I checked the plugs to ensure they were tight and latched - still no movement on the mirrors.
I inspected the driver's side - all pins were good. Upon inspection of the passenger's side, I noticed one pin, slightly bent. I straightend the pin and to my surprise both mirrors returned to full functionality.
It is baffling that Jeep would design such a substandard plug for a plug that, more than likely, will get unplugged/plugged dozens of times over the lifetime of the vehicle.
Jpogar10
Jono
Virginia
2019 JL Rubicon Unlimited, 2010 JK Sahara Unlimited
Did you or anyone else take a picture of the bent pins? I am having the same problem after replacing my doors and I can’t tell if any are actually bent. It has affected both mirrors on mine as well.
Espinosa21
Carlos
New Jersey
2021 Rubicon JL
I just fixed mine this morning but didn’t take a picture. The remote start and power mirrors weren’t working but door locks and proximity worked.
I had to detach the connector from the inside body of the Jeep so I can see the pins. Some of the smaller pins were slightly bent upward compared to the others but it’s not something very obvious. I bent them back with a tiny screwdriver so that they line up with the others and everything worked when I reconnected. Both of my doors had bent pins.
L06An_5
NJ
1999 TJ Sahara; 2019 JL Rubicon; 2021 JLU Willys Wheeler
Best picture of the pins I could get. I have a few other angles but not as good on clarity.
Driver Side:
Jeep Wrangler JL Power Mirrors and Lock Not Working 20220611_150334
