Power mirrors not working
The1NonlyLue
New York
Wrangler
I recently put my doors back on since summer is over and the power mirrors don’t work. The blind spot and locks still work. It is an 18 jlu and out of warranty and I don’t feel like paying 200 just to have the tech at the dealership look at it.
I removed the mirror to make sure the pug was in and it was. Is there a way to find what pin in the harness is for the power mirror wire. One looks slightly bent but I’m not too sure
6.2Blazer
Ohio
2019 JL Sport
I'm assuming you looked at the door to body connector closely? I would disconnect and look for any corrosion or dirt on either end, especially if they have been off for awhile. Then try reconnecting and making sure the connector is fully seated. If they were working, you then unhooked the connector, and when you reconnected it they are not working that is definitely the first place I would concentrate on.
I know you said you removed the mirror and mentioned a connector, but assume at the actual mirror?
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Check your door connectors. You bent a pin.
Grab a pencil, carefully pull the lead so you leave a hole and straighten the pins with it.
