AndySpill
- Andy
- Oct 24, 2023
- Pittsburgh
- 2018 JL Sahara
I have an Anderson plug on the front of my JL.
It looks a bit like this:
It's wired, through some 2 gauge wire, directly to the main battery with this stuff:
Having the Anderson plug in front makes it easier for me to hook up electric things, from a snow plow in winter to jumper cables.
But I don't like that the plug is energized all the time. If someone sticks a piece of metal between the two connectors on the front of the Wrangler they could reek havoc with the vehicle's electrical system.
So one solution is to put a battery on and off switch between the plug and battery, like one of these:
But its wiring has to be no less thick than that leading to the Anderson Plug for safe high amperage--plus, the whole idea of the Anderson plug was to not have to pop the hood where this battery switch would be each time I want to energize the Anderson plug. I don't want to bring such thick cable into the cab, losing ampacity in the process.
(And sure, I could hide the Anderson plug in front.)
So I was thinking about using a starter solenoid relay to do this switching. Using thin on/off switch wires that I could bring into the cab, and given this device's 800 amp capacity, what do people think about this way (is there a better one) of controlling the energizing of the Anderson plug in front
They make these with wireless remotes, which with my luck will have its watch battery die in the very cold temperatures I need to plow in, so I'm leaning to hard wiring the on/off switch.
And they make these for winches, but I don't need (I don't want) to change polarity to get a winch motor to spin in opposite directions.
Sure---I have a trailer hitch power port in back that's no less vulnerable, only its fuse and thinner wiresprobably don't allow much damage to the vehicle's electricals like this setup in front.
And yeah, maybe I'm being a bit overprotective of the Anderson plug, or complicating this.
I do such things from time to time.
TIA
TIA
