Please Critique My High Amp Switch
AndySpill
Andy
Pittsburgh
2018 JL Sahara
I have an Anderson plug on the front of my JL.
It looks a bit like this:
Jeep Wrangler JL Please Critique My High Amp Switch 1716998738671-ff
It's wired, through some 2 gauge wire, directly to the main battery with this stuff:
Jeep Wrangler JL Please Critique My High Amp Switch 1716998850151-ey
Having the Anderson plug in front makes it easier for me to hook up electric things, from a snow plow in winter to jumper cables.
But I don't like that the plug is energized all the time. If someone sticks a piece of metal between the two connectors on the front of the Wrangler they could reek havoc with the vehicle's electrical system.
So one solution is to put a battery on and off switch between the plug and battery, like one of these:
Jeep Wrangler JL Please Critique My High Amp Switch 1716999094897-u0
But its wiring has to be no less thick than that leading to the Anderson Plug for safe high amperage--plus, the whole idea of the Anderson plug was to not have to pop the hood where this battery switch would be each time I want to energize the Anderson plug. I don't want to bring such thick cable into the cab, losing ampacity in the process.
(And sure, I could hide the Anderson plug in front.)
So I was thinking about using a starter solenoid relay to do this switching. Using thin on/off switch wires that I could bring into the cab, and given this device's 800 amp capacity, what do people think about this way (is there a better one) of controlling the energizing of the Anderson plug in front
Jeep Wrangler JL Please Critique My High Amp Switch 1716999564224-gq
They make these with wireless remotes, which with my luck will have its watch battery die in the very cold temperatures I need to plow in, so I'm leaning to hard wiring the on/off switch.
And they make these for winches, but I don't need (I don't want) to change polarity to get a winch motor to spin in opposite directions.
Sure---I have a trailer hitch power port in back that's no less vulnerable, only its fuse and thinner wiresprobably don't allow much damage to the vehicle's electricals like this setup in front.
And yeah, maybe I'm being a bit overprotective of the Anderson plug, or complicating this.
I do such things from time to time. ;)
TIA
Left Field
Tim
Western WA
'67 RS-SS Camaro, 2021 JLUR392
Hi Andy,
I recently installed the Warn shutoff solenoid on my Jeep. It doesn't do any polarity switching, it is just for allowing remote on/off which I accomplish with an aux switch.
https://www.warn.com/power-interrupt-kit-62132
The negative is that it doesn't appear to specify a current rating (however winches routinely are expected to draw 300-400 Amps).
The positive is that it seems to have a decent duty cycle. If memory serves I found the solenoid they used at an electrical parts house and it was rated continuous.
Many of the 'starter' type solenoids have a very short 'on' duty cycle.
I've considered doing a similar setup as you are proposing, your plan looks well thought out.
LF
Mike_Hawk
Illinois
2022 GOBI JLUR 3.6
Mechanical Engineer
Hi Andy,
LF
How did you mount the switch? I have the same one but mounting it is daunting.
Jeffy56
Payson, AZ
2018 Wrangler Unlimited Sport
I highly recommend some sort of fuse or breaker so that if bad stuff happens you don't cripple your Jeep or cause a destructive fire!
Left Field
Tim
Western WA
For mine I was able to drill holes through the rear of the body panel mounting flange adjacent to the battery. On the 3.6L the battery and ECU locations are different, but there are still bolts along the body panel flange that likely could be used with an angle bracket to mount the relay.
LF
THAW
Foster
23 JL4DrRubicon
Hi Andy, you know how much I enjoy critiquing your electrical concepts 😁 ...
...the primary concern in shorting the Anderson connector - effectively extended battery terminals - is damage to the connector, 2 gauge cables and/or battery resulting in a fire, not electrical havoc in other circuits.
Having stated that, why not appropriately fuse (e.g. 125 A midi) the positive 2 gauge lead at the battery terminal, then in the event of a peak/non-continuous application (e.g. jump start) bypass the fuse holder/block to make a direct battery connection? I assume jump starts are unlikely/infrequent enough to make bearable the inconvenience of popping the hood.
You could still use Anderson plug equipped accessory cables (e.g. jumper cables) for peak/non-continuous applications by swapping a single ring terminal on the fuse holder/block - perhaps using wing nuts to make the process toolless. Or if you don't want to rearrange connections, use a 3 way bypass switch (e.g. Blue Sea 6008) to provide disconnected, fused, and unfused settings.
Basically: fuse the Anderson connector and switch it to unfused for edge cases, thereby protecting it from short and minimizing switch location significance.
roaniecowpony
Retired Engineer
If you ever have an actual dead battery for whatever reason, the solenoid would not have power to tie your Anderson circuit to the main battery.
lashlee
Knoxville, TN
'18 JLUR 2.0 Turbo 4 (Sold), Tesla M3P
If you don't want it powered all the time, why wouldn't you simply leave it unhooked until you need it. No additional wiring, relays, or switches.
I've used them on vehicles since the late 90's and have never had any issue with it, simply hooked straight to the battery. I did use a fuse, though.
missionale
Jeepie
West of the Rockies
2021 JLU
Fuse - definitely. To keep things simple, what about a cover or spring loaded weatherproof to avoid debris-shorts-accidents.?? Or place your Anderson plug by your battery (with cover) and use a jumper when needed to front bumper location???
Jeep Wrangler JL Please Critique My High Amp Switch Captur
Jeep Wrangler JL Please Critique My High Amp Switch Capture1
Jeep Wrangler JL Please Critique My High Amp Switch Capture2
roaniecowpony
Retired Engineer
Kinda pricey, but you could use a 4xe charge port panel. They are using them for the onboard air QD on some installations.
