DanW
Looks like it kicks ass, to me! I really like that antenna mount. It has a better shot at a good ground than any I've seen outside of the spare tire carrier, but I don't think they get high enough, and antenna height matters.Hey gang, let me know what you think or what I’m doing wrong! New to it all, doing as much reading as I can.
So, my American Adventure Labs NMO mount has shipped.
Planning this Larsen NMO and coax with the uhf male connector, bc it is purportedly more resilient to weather given the construction. I’ll put heat shrink on it too. Part # NMOKHFUD. Trying to see if the seller would cut it to a 10’ length for me, vs the 17’ that comes standard. I want to avoid having a span that just lies coiled under my carpet.
And I’m thinking the STI-CO flexi-whip 1/4 wave antenna, is a good choice, can tune for GMRS. it’s super flexy, seems to have good reviews. I have read that the phantom / stealth style antennas are not great performers, and the 6db antennas are meh for mountains and the db claims are dubious (?). From my reading, sounds like a 1/4 wave antenna tuned for GMRS is a solid choice.
I have the Wouxun kg-1000g radio. GMRS is new to me. Have been getting some education from itsnotarubicon on YouTube. Just reading the radio manual, I’ll have lots to learn!!
…and the Rugged Radios mount, which will position the radio on passenger side of center console. (For now, I’m not planning to mount the detachable faceplate on the dash…kind of like keeping the dash area clean, and for now at least, I don’t anticipate a need to be hands on the radio constantly. Simplex at least will be set it and forget it.)
The mic will ride a magnetic-mic mount with a 67design ball mount. Either on the grab bar or possibly on an arm from the 67 designs rail mount.
I anticipate wiring straight to the battery.
Tell me what you think, welcome any pro-tips!!
Love everything else. Mine is similar in some ways. I've got the KSG1000 radio, as well. I like it but I think I'm going to go back to Midland when the MXT575 comes out. It's just such a clean mount.
I put the chassis for the KSG 1000 under my seat, but off the floor. I used a little Amazon steel bakers rack and zip tied the chassis to it and it to the seat slider mechanism so it gets cool air all around and stays up out of any moisture that could potentially sneak in there. The downside is that I have to run an external speaker because the main one is just not loud enough. For the price of that thing they should have stuck a much more powerful speaker in there, like Radioddity did with their 20 and 25 watt radios. Those are LOUD. The speaker in the mic is a joke. The MXT275 had the balls to be heard with its much better mic speaker. And it was so much less cluttered than the way I'm running it all right now.
Below are some shots of my setup. I've got the KSG1000 face plate on a RAM mount but will likely velcro it to the flat dash space right under it to bring it down a bit.
I'd love to get our two Jeeps out in the desert or flatlands somewhere and see how far we can reach each other with these 50 watt beasts. That'd tell us how our antenna setups are working.
Both the JK and JL have the antenna on the same mount and use the same Midland 6db antenna.
THe JL isn't too bad. That wire on the right is to a dash cam. I'll be cleaning that up this summer.
The JK set up is a little simpler, with a Radioddity DB25G on top of the dash. Man, that speaker is LOUD. It would be no trouble to hear it on the highway with the doors off and top down! The CB speaker above the rear-view fires straight down and is equally loud (Thanks, Uniden!) and easy to hear.
